92 manual into 96 auto
Old Sep 5, 2005 | 06:08 PM
Fuzzymemo's Avatar
WORKED! 92 manual into 96 auto
yes, I have done my search and did crazy emails to everyone but have yet to have an answer. and this is my final and last resort, so please help me.
Here's the thing::
I have a auto 1996 240sx se. It is gutted out laying in my backyard. My brother is giving me his 1992 240sx se engine+manual tranny. Becasue he's doing his sr20det swap right there as well. He's using his lower and upper harness (like how they always use them with the sr20 harness). So what I'm left with is a 92 engine+manual tranny into a auot 96 with auto 96 harness and ecu. WOULD THIS WORK?
I need as much help as possible, I need the car for college and I been working all summer longer and i just started working on the car 3 days ago...just waiting for an answer and I put that shiit in right away, so please please help me. TIME is a major issue for me,classes starting in 2 days. SO PLEASE....HELP A BROTHAAA OUT!!!
flame as much as you want, but I highly doubt anyone asked this question ever yet...I just need her to run, fuc passing emission or anything at all, just run run run run...just run pleaseeeee help..thaknk you thank you thank you
Old Sep 5, 2005 | 06:23 PM
Fuzzymemo's Avatar
bump...I'll give the dude who can help me out to the max 10 bucks...and who can make it work 20 bucks..,....I am serious about this...an dif I like you so much I might even dare to think of 100 bucks....seriouslly...HELP
Old Sep 5, 2005 | 06:27 PM
no need to bump you only posted it like 20 mins ago. The 1996 is OBDII, so if I'm not mistaken you will need several parts off of an OBDII 240sx and
Old Sep 5, 2005 | 06:44 PM
Fuzzymemo's Avatar
that's my problem there's no obdII around for me to take parts out of...time is a mjor issue....
Old Sep 5, 2005 | 07:05 PM
Fuzzymemo's Avatar
did I mention, I passed the point of no return...well there is a return...but it would be a big shame....i mean i would return once the time is up and I just HAVE too....so please don't let me return her into a ****ty 4 speed auto transmission...PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EE
Old Sep 5, 2005 | 08:11 PM
devnull's Avatar
The 92 transmission won't have a crankshaft position sensor. It's located in the bellhousing. The CEL will come on without the crankshaft position sensor.
Old Sep 5, 2005 | 08:14 PM
nsn240's Avatar
i think the tranny will physically fit, and work right, because nissan used the same trans though out a lot of their cars... i dont know about the wiring aspect though
Old Sep 6, 2005 | 03:37 AM
dude, your car is OBDII, take the '92 engine, grab the **** you need from your engine and throw it on
Old Sep 6, 2005 | 05:16 AM
Hope it works. I wish i had 100 bucks. The edit button is useful btw.
Old Sep 6, 2005 | 06:03 AM
Fuzzymemo's Avatar
s13240, thank I'm gonna try that...even though I don't have the slightest clue, but haha...
early morning waking up hoping for a bright ray of hope on my car
Old Sep 6, 2005 | 08:48 AM
BigVinnie's Avatar
Jet chips will reprogram and send out the right ecu in under 24hours it is there policy. All you will need to do is send in your ecu later in order to get your deposit back.
For easy install use the 92engine and tranny, while you are at it install the 96 intake mani onto the 92engine, this will remove the secondary butterfly's for added power, about 6 more CHP over stock. Install all your bolt ons from the 96.
Make shure you let Jet know all modifications that are made. That includes the crank angle sensor that is on the 5speed manuals, and the removal of butterfly's. It's cheaper than JWT.
This way you can use the same wiring harness.
Old Sep 6, 2005 | 09:32 AM
BigVinnie's Avatar
I p.med you with the JET web site, let them know that you are installing a 92 engine into your 96, so that they can reprogam the difference in the cam lobe and duration from the 96 to the 92 engine.
Or you can keep the fuel dump that you have and just do the hot cam set up 248/232.
Old Sep 6, 2005 | 07:58 PM
devnull's Avatar
You might need the 90 degree water outlet from the 96 engine. It's on the side, right by the front of the engine. The one on the 92 engine might be in the way of the throttle body.
Old Sep 6, 2005 | 08:21 PM
Sleeperella's Avatar
oh okay, thanks alot guys, it seems like it's all going to work out just fine...my stupid friends had me scurr for a moment...a long *** moment. thanks alot I really appreciate all of them. I suppose what I had to begin with was alright, just I have to wait till the weekend to finish her...and I need to order some gaskets and transmission fuild that I didn't think of...thanks again..I'll keep you guys updated once she's working
Old Sep 30, 2005 | 04:26 PM
Fuzzymemo's Avatar
it beem a month now, my baby still not on the road. I ordered trh tranmission fluid redline it have not come yet, been 3 weeks. fucen **** off about that. But I cranked my baby, dry, she did not go. She sputter but just won't go. Some people told me it's the distributor since I took mine 96 distributor and just jam the **** in. I tried to do teh TDC thingie to the first spark plug and would attempt to do the timming right tomorrow. I don't have a "timming gun". But yea so what else you guys thinks is the problem?
this is what I done so far
1. install 92 manual engine + tranny
2. used 96 auto ecu and harness
3. splice the starter circuit
4. connect reverse sensor
5. installed clutch master cylinder, slave, and piping
6. installed the driveshaft and relocated the support
7. connnected all the lines, using all 96 tubes, holes, wires
8. turn on car, lighting, sterio, everything work normally
9. cranked....no car....
10. checked everything over and over again
11. tighten all bolts and ground wires
12. checked for fuel, spark, and power
13. system all green(go) but she no GO,
14. cry
15. cry
16. cry
17. (this have not been decided yet, so please help me anyone)
(oh yea once my car start,there is this guy who I'm sending 10/20 bucks too casue he been helping me alot, but if you can do something else for me, maybe you too will get luck)
