96 240sx need help fast
Old Jun 20, 2006 | 04:47 PM
InitalS's Avatar
hi
I need help anyone out there know alot about 240 i have an 96 and i swap a 95 240sx motor into my since my 96 motor not working well but I smog my car and is didn't pass Smog Should i change the ecu also or not or just Reset the code on the ecu on my 96 or i have to change to the 95 ecu from the motor i put it in?? anyone let me know asap thanks..
Old Jun 21, 2006 | 01:31 AM
Well what part of the smog check did you fail?
Old Jun 21, 2006 | 05:22 PM
Helghast's Avatar
let me tell you...
you didn't fail cause of the ECU.
Old Jun 23, 2006 | 12:21 AM
InitalS's Avatar
what can i do to make it pass smog? it have check engine light on and the code saiding is the evap purge control and the fuel& air meterius that's what is said you guys should know what is it But i was thinking the 95 motor the throtty is different from the 96 so i have to change the throtty from the 95 and replace the 96 Is it because of that of not passing Smog?? let me know thanks...
Old Jun 23, 2006 | 12:41 AM
It's not passing because of the codes (CEL= auto fail), fix what ever codes its throwing, then reset it, check for codes again and if everythings good then it should pass.
Old Jun 23, 2006 | 07:02 PM
InitalS's Avatar
So if i fix it and reset the code it should pass smog is that to hard to fix the check engine light right?? But i planning to convert my to stick shift as well. Well it bring up the check engine light out agian or not?? Cause the ecu is an obd 11 also. let me know you guys thanks...
Old Jun 23, 2006 | 08:57 PM
The CEL is there for a reason, you are throwing codes. You pulled the codes and it told you what was messed up. Go and fix whatever the codes said was messed up, reset the ECU and then check the codes again. If no more codes show up you should be fine.
Old Jul 7, 2006 | 11:47 AM
Badazz_240's Avatar
Ever hear of a period?.... or other grammar skills for that matter?.... sorry for being mean, but seriously
Old Jul 7, 2006 | 01:26 PM
drewman752's Avatar
i was about to say that same thing... my head was about to explode
s13 240 u da man
carcrzy920
Sep 28, 2008 07:03 AM
drftbot
Jan 17, 2007 08:30 PM
gk.
Sep 10, 2004 07:08 PM
cheap240
Oct 15, 2003 09:51 PM
Noodles
Oct 5, 2003 10:03 AM
