Air Fuel Gauge
Old Mar 25, 2004 | 09:46 PM
Brads_SR20DET's Avatar
Question Air Fuel Gauge
All right, i know not everyone here may be a supporter of sucha useless gauge but....im havin a bit of trouble hookin up my air fuel. its a 1991 hatchback with the sr20det swap, i have good hookups to ground and 12v, but the actual o2 sensor that im tapping into is giving me trouble i think. first, does it matter which wire i tap into as long as it goes to the sensor, and second, should i tap into the part that goes from the sensor to the harness, or from the harness to the ecu? thanks for any replies and/aid yet to be received
Old Mar 28, 2004 | 03:38 PM
ryan15's Avatar
2 days and know one answered. I have no idea but try to hook it up to the actual o2 sensor wire if you you hooked it up to the o2 wire or the one the goes to the ecu im guessing is the same thing. Just try it and see what happens.
Ryan
Old Mar 28, 2004 | 07:25 PM
JeromeS13's Avatar
I'd hook it up to the wire going to the ECU. According the the FSM for the KA, its pin number 19 (white wire.) I'm not sure about the SR ECU, though....
Old Mar 28, 2004 | 08:01 PM
backlife's Avatar
if u have an ohm meter you can find out which wire is ground, sensor and heat if it is heated
topsecretgold
Aug 4, 2005 10:31 PM
doua
May 9, 2005 06:34 PM
ryan15
Jul 12, 2004 12:12 PM
ridesnowx4
Jan 24, 2004 05:05 PM
Dom
Feb 10, 2002 12:03 AM
