Another buying a 240 thread (need more info)
here's the deal. I realised I work on my car alot and want a dialy driver. I was going with a civic or something but them I realised I can get a 240 fairly cheap also(like 2-3k)
I know I want to start a 240 project after I get bored of the GST I have now. So why not get the 240 now an slowly mod it then make the GST the daily since the 240 probably has more potencial.
-other than basics stuff you look for when buying a car, is there a downside that I should know about these cars.(trannies,rear end,ect)
-I was looking for like a 91-94 hatch about how much do those weight
can toss any other useful here too, thanx
oh, here's my eclipse so far http://www.cardomain.com/id/mywhirl2
Originally posted by spitz7985
'94s were convertable auto only
240s have timing chain problems, you will probly need to change it around 100K miles (~$200 if you do it yourself)
thats the only problem i can think of right now
www.Edmunds.com This is a good site to get some nasic info on them.
Chad
Originally posted by EvilCerealBoX
you work at a car lot? think you could get me a good deal on an 240sx fastback or maybe an s14 (preferable 97-98) 5 speed manuel ?
Originally posted by Dave41079
No, he works on his car A LOT. It's a DSM, that's typical.
Originally posted by kaos
What are some of the early signs that you need a new timing chain?
you will hear a rattling noise coming from under the timing cover (behind the fan) when your timing chain starts to go.
its actually the plastic chain guides that wear. the chain itself will never break, but if the guides wear, and the chain gets loose, and skips a tooth or two, you will lose power, gas mileage, etc. if the cam timing gets too far off, pistons hit valves. (thats not good)
timing chain tensioner
and the brakes like to stick. i've had to rebuild my rear calipers and free-up the fronts.
i'd advise anyone buying a used S13 in the northern U.S to get a $7(per axle) caliper rebuild kit and replace all the seals and what-not.
Bryan
Jun 25, 2006 09:18 AM
