Banging Noise In Rear End!
Old Jan 19, 2005 | 06:40 PM
IGotWorms419's Avatar
Question Banging Noise In Rear End!
I have a 95 240sx and it makes a banging noise in the rear end. It does it when i dont shift smoothly, when i floor it from a low speed and idle, and when i brake quickly and then release the brakes. The guy that sold me the car told me that i needed to replace the bushings on the differential. Does anyone know about this problem and if it is the bushings where r they located. If its not the bushings, what else can it be? Your help will be apreciated.
Old Jan 19, 2005 | 07:55 PM
needa240's Avatar
I bet you have an aftermarket exhaust, and MAYBE even a aftermarket sway bar in the back.
Right????
That sound is your exhaust thumping on your rear sway bar or diff. I have the same annoying thing.
Old Jan 19, 2005 | 07:58 PM
No... its not my exhaust cuz it happened when i had my stock exhaust.
Old Jan 21, 2005 | 09:26 AM
needa240's Avatar
and you dont have aftermarket sway bars????
Damn. I'd really like to know what you find out then. Mine does the same thing, but i always thought it was the exhaust.
Old Jan 21, 2005 | 11:03 AM
Project Cheap13's Avatar
Check for driveshaft play. It's either your ring & pinion or your tranny out put shaft.
OR worn u-joints.
Old Jan 21, 2005 | 11:16 AM
needa240's Avatar
I can make mine "BANG" in neutral. I think this guy is experiencing the same thing, but not sure.
I can coast in neutral, hit the brakes hard, and let of real quick and it will make the thumping noise.
That means it shouldn't be anything drivetrain related. right?
Old Jan 21, 2005 | 05:36 PM
subframe movement maybe due to dead bushings?
Old Jan 21, 2005 | 07:04 PM
bottombunk's Avatar
mine was the same way. ii replaced the bushings and thats all it took. i replaced the subframe bushings not just put in subframe collars. so i dont know but the collars might do the trick.
Old Jan 21, 2005 | 07:09 PM
jbask's Avatar
Old Jan 21, 2005 | 07:42 PM
needa240's Avatar
How hard is it to replace those bushings????
Thanks!
Old Jan 21, 2005 | 09:36 PM
95_240SXSE's Avatar
Yea this sounds most definitely like worn subframe or differential support bushings or maybe even both.
As far as install difficulty, it should be doable with jack stands and of course the proper tools.
Old Jan 21, 2005 | 10:20 PM
subframe bushings should go right in (be careful to properly support the subframe when you unbolt it) but if you have to mess with any suspension bushings, you'll need a hydraulic press, or some drifts and a huge hammer.
Old Jan 22, 2005 | 12:20 AM
needa240's Avatar
how do you "properly" support the subframe???
thanks!
Old Jan 22, 2005 | 01:37 AM
thanks!
floor jacks in the right places
Old Jan 22, 2005 | 05:40 AM
If it were the subframe/diff bushings would it not do it all the time. Not just during accel or deceleration. Like going over bumps, hitting pot holes, ect..
That has been my experience atleast.
