Brakes
Old Nov 3, 2003 | 04:46 PM
thaibrawler's Avatar
Brakes
I was wondering, since the ABS feature is an option for the s13. Is it better to find a s13 with ABS or without ABS. If without ABS what upgrade to the brake can you do?
Old Nov 3, 2003 | 07:20 PM
drnovascotia's Avatar
you can upgrade to 300ZX brakes, a very commonly done mod. Some people like ABS, I do not. Thats a preference.
Dr.
Old Nov 3, 2003 | 08:35 PM
There are lots of options when upgrading brakes..u can go all out and do a rotora/brembo big brake upgrade (2k at least) or go for a Z32/R32 brake conversion (around 1k-1.5k) Or just upgrade ur lines..rotors and pads for pretty cheap. Do a lil research on all of them to see wuts best for u
Old Nov 4, 2003 | 04:30 AM
ixcocoyxi's Avatar
fawk it.. the answer to all problems.. two words.. ZIP TIES .. they are so versitile arnt they?
Old Nov 4, 2003 | 05:53 AM
Sil40_Mayhem's Avatar
Re: Brakes
i read a review (maybe at edmunds.com?) that stated that the ABS system as found in some S13's is quite primitive, and less likely to be very helpful. ***k it, i dunno, research it!
Old Nov 4, 2003 | 06:53 AM
wel wouldn't that make it like the Hicas LSD? Primative, however still works well. Still better than no ABS depending on the person. Myself, i'd rather have full control, heh.
I don't get what zip ties have to do with ABS brakes, but ok
Dr.
Old Nov 4, 2003 | 10:01 AM
original ABS = pump the brake pedal as fast as u can.
Old Nov 4, 2003 | 11:20 AM
I researched and found that the z32 will cost about 952(pdm). Right? I think rotora big brake kit is 2166. If im not mistaken that is only for the fornt right? So what could I do with the back?
Old Nov 4, 2003 | 11:52 AM
There are sum places that sell the rear brake Z32 conversion as well. REMEMBER this, u will need bigger rims and certain ones becuase the caliper is a lil bigger then usual. dunno if that made sense but yea..
Old Nov 4, 2003 | 01:19 PM
Re: Brakes
I'd say it depends on what you'r eplanning to do with the car. Drift? Drag? Grocery shopping? Teen driver education?
Rotora is overkill but WOW makes me drool
Old Nov 4, 2003 | 03:56 PM
JuJuBeee's Avatar
front z32 conversion is about 500 buckers and it WILL clear stock s14 rims....not talking about blackies or steelies but the 16" alloy rims (its a little close though )
the biggest difference in price is if you deicde to get new calipers or rebuilt ones....
Old Nov 5, 2003 | 10:09 PM
TougeMonkey's Avatar
Or learn the braking limits of your car so you don't have too!
...and if you don't have ABS you can use the brakes as more of an advantage with weight transfer!
Old Nov 6, 2003 | 10:14 AM
Most people I know just get the 300zx brakes up front, I have no clue why, but it is sufficient, i've driven in one and absolutly loved it.
Dr.
Old Nov 7, 2003 | 08:55 PM
TruDirtyPlaya's Avatar
wondering? you cant go to a junk yard take those brakes and rims and clean thoughs up and swap out? seem like that would be cheaper?
Two-Fortee
Feb 15, 2008 02:22 PM
FSPtwo4d
Dec 10, 2002 09:06 PM
wicked240
15
Nov 30, 2002 08:20 PM
rudeboy
23
Oct 1, 2002 02:54 AM
MI SO FST
Mar 27, 2002 09:05 AM
