can I get longer bolts...?
I got a set of wheels, they're the right pattern (4x114.3) but the bolts are too short to get the lug nuts all the way on. Can I get longer bolts to put in??
Yes studs....go to your local autoparts store or http://www.courtesyparts.com/nms/s13/s13_5.html do you know how to change studs? Its not that hard just wondering if you know how...
pics would be awesome, cuz I dont have the slightest clue?
THANK YOU!
EDIT: What are the exact sizes I'd need to look for? And what length are on the car stock? What size should I go for...the 50mm or 60mm?
THANK YOU!EDIT: What are the exact sizes I'd need to look for? And what length are on the car stock? What size should I go for...the 50mm or 60mm?
Remove caliper, rotor exposing the hub and studs (of course)
I used "Gibbs" Penatrating stuff to loosen up the studs. It was laying around in my garage. WD-40 may work...
Use a mallet/hammer and just hit the studs on the head untill they come off.
When your ready to put ithe new one back on, Insert the stud through the back.
Add a few washers so you wont strip the nut and use an air gun to tighten the nut until the stud is secure in its place.
Thats the best explanation I can conjure. Took me a few minutes...Sorry no pics. Ask s13 240 what size the stockers are and determine what size you need. You can also ask someone at your local autoparts store...
there's something not right if the OEM bolts aren't long enough to put a lugnut on. Are you even sitting the face flat to the hub?
What wheels are they? What car did they come off of? Give more details.
The arp studs are not right for the 240sx, they are 12.5 X 1.5 while 240's would need studs with 1.25, granted you could still use them but you would have to get all new lugs.
I'll try to get the pics of for you God in a bit, just got off work and gotta pick up my camera with the pics at my friends house.
no problem, thanks! I had to go out yesterday to get gorilla lugs to fit in the wheel, cuz the lugs are recessed (sp?) into them. The original lugs off the car wont fit.
silentvoice19
Oct 22, 2006 06:35 PM
jackyliem
Dec 14, 2004 12:22 PM
