car is almost done with .but...
Old Oct 7, 2007 | 08:30 PM
FinaL's Avatar
well the cars been sitting for nearly 2 yrs, and well when i started workin on it i replaced alot of part
plugs
cap
rotor
wires
fuel filter
air filter
rear and front breaks
upper and lower radiator hose
dual electric fans
valve cover gasket
injector seals
rear sturts
belts
right now im haveings a bit of over heating issues
well i got a new thermo the other day and well i been lossing water i replaced the rad butt that was 2 yrs ago just sittin in the back of the car.
when i took off the thermo cover to replace it, i notice it didnt have a thermo
will this be y im over heating? granted im putting one in but i also broke the cover that bolts on to the block.
the car has never gone up to all the way hot just mid level on the gauge
with the dual fans and an over ride switch it makes it alot easyer
something is tell me im gona have to replace the radiator..
Old Oct 8, 2007 | 01:11 AM
re037's Avatar
you bled it right?
Old Oct 8, 2007 | 08:31 AM
FinaL's Avatar
i cant cuz i broke the housing for the thermostat
Old Oct 8, 2007 | 06:18 PM
FinaL's Avatar
ok so i made some calls today to find a new thermo houseing couldent find one at all so i on my wat to the junk yard a get a call from a local guys tellin me he has my rear caliper and master rdy so i go and pic them up payed 35 for them both, so i goto the junk yard and pulled a new thermo houseing
get home put it all back together and load and behold everything is working great after replacein the radiator cap also helped out
had an issue with me brakes lockin up when i would drive well after 3 brake bleeding it all worked it self out
mcampbell26
Sep 24, 2005 10:17 PM
cdigity
Jun 15, 2004 02:43 AM
Krea2nr
Jun 14, 2004 11:35 PM
chrs13
May 2, 2004 11:49 AM
tater
Feb 24, 2004 08:34 PM
