car is not level, any answers??
no collission damage, and have changed out springs with tein, and kyb struts. car is lower on the front driver side. nothing looks bent. what do i do????
Originally posted by Bluetwo
i gotta say I've never heard of this problem before,
Hope you figure it out.
It normally requires replacement of the spring & strut/shock.
Like he said damaged ball joints. There is his awnser right there. Suspension damage.
that depends on if he switched to Tein/KYB before or after he noticed the height difference.
Tein has staggered lowering but nothing major, plus front and rear springs can't be interchanged no matter how hard you try
Have you actually measured the difference? Try using a tape measure, go to somewhere relatively flat (concrete is better) and take measurements from the ground to the highes part of the fender, then report back with results
NismoHead90
Jan 29, 2010 01:17 PM
