Car problems after dash install/ autocross
nstalled my new dash today. Now my radio doesnt work. Clock flashes and resets everytime i start the car. THe open door light is on. And there is a relay clicking somewhere underneath the dash. I rechecked all of the wiring and everything is fine. Any ideas??
i autocrossed it today then it also started doing more things. The e brake light stays on and the battery light stays on. The car also stalls and when it idles it runs at like 500 rpm
A relay click loud sometimes means it won't work IE: Starter Relay
It sounds like you have a bad ground somewhere as the clock resets. You possibly shorted something out as well, did you check the fuses to see if any were blown. Engine Bay/Kick Panel inside.
For ebrake check to see if the fluid resvoir is up to level.
s13slider44
Jan 15, 2006 05:04 PM
