car starting issues
car starting issues
my car is having issues with starting sometimes. Like before it was because my terminal was coroded about 2 and a half inches, got that fixed... but i still face the problem of sometimes it doesnt start on my first turn. I figured i have to pump the clutch an extra one or 2 times then it starts and then even then sometimes the rpm starts dropping dropping and the car dies again. So to compensate for that i give it a small rev to keep it from dropping... anyone know what these problems are and how i am going to go about getting it fixed.
uhmmm no smell, well when it doesnt start i turn it on and everything shuts off i dont really hear anything. Then when i pump the clutch twice i i turn the key it starts, it revs to like 1.5 then starts dropping real quick unless i hold the key turned in the ignition or give it some gas to keep it from dropping to zero and dying.
ok then, pumping the clutch does nothing other than close the circuit for the inhibitor switch. if you have to press down a few times then more likely that nor you need to replace that switch.
i'm curious about the idle, what other information can you think of regarding it?
not much of a car guy so where and what is the inhibitor switch so i can get that checked out and now about the idling. I don't really know too much, all i can say is there are times when it starts idling low and then almost dieing but it comes back up n drops n comes up slightly n sits and is okay. Though ussually it drops and dies like that when it is the first start of the day or when in about a 3 hours time i start it up. I think it may be when its not warmed up it does that. Ussually that doesnt happen if i have been driving it for a while.
the inhibitor/interlock switch is behind the clutch pedal, there's really not much to check out on it so i recommend you just buy a new one. the easy answer for the idle problem would be a faulty iacv since it's a common problem, but i'm not convinced that that's your problem. you should check the ecu for trouble codes, even if the cel doesn't come on, there may be a fault.
