chassis fixable???
Old Jul 16, 2005 | 06:37 PM
FUNGC's Avatar
Unhappy chassis fixable???
well my friend set a jack stand under the car today to fix up my 240 soo i could fix it. itz a 1990 240sx and then we placed tha jack stand where we usually put it. but this time when we were lowering one side of the car, the other side of the chassis collapsed due to rust on that beam on the chassis, it fully went in! im not sure if this if possible to fix, like could i pull it out and re-weld it or sumthing? =\\\
i just bought my car for 300 too! =\\
Old Jul 16, 2005 | 06:46 PM
silviadriver's Avatar
might wanna let poeple know where you put the jack stands. some poeple dont know where they exactly go
Old Jul 16, 2005 | 06:49 PM
FUNGC's Avatar
its where the beam is under the car, like prolly round the middle, not sure wut it really is but that part is tha safest underbody part of the car. i might have pics later this week when i go back to my friends house.
Old Jul 18, 2005 | 12:53 PM
Shri222's Avatar
unibody chassie pain in the *** to fix
Old Jul 18, 2005 | 04:49 PM
FUNGC's Avatar
i think tha part was called "frame rail" thatz wut i sorta found on tha net. still dunno if itz possible to fix myself, probably like weld it back after i pull it back down or somethin
Old Jul 18, 2005 | 06:36 PM
Cape 240's Avatar
if your frame collapsed ... iwouldn't really trust a weld to fix it lol...
Think, your going down the highway at 120 ... you hit a dip, frame snaps.....
no good .. lol
Good luck, hopefully its not as bad as I made it out to be.
Old Jul 18, 2005 | 06:44 PM
FUNGC's Avatar
well do you guys think that if i weld it and den reinforce it with like more sheet metal on top of it will make it safe? and also make it pass safety test? cause i still havent done safety or anything yet
Old Jul 18, 2005 | 08:16 PM
Preston's Avatar
First, if it's rusted....you need to cut far up and downside of the rusted area...because rust is a chemical reaction. What you see is the final result. There is still that reaction going on where u can't see it. So cut out a good sized portion of the frame rail, rectangular preferably. Next get some of the same material (I don't know what it is steel?) w/e it is. Weld that onto the hole you just made, WELD IT GOOD AND STRONG. As good as you can and as strong as you can. If you want extra reinforcement you can foam fill that section and/or weld another piece of metal over the hole-filler piece that is longer and goes past the first welds. Then you should have a strong replacement piece for it. NOTE: probably will never be as strong as stock, but it will work.
PS: I had to do this to my 240 when i got it. Frame looked like swiss cheese. Never got to test how strong it was due to @$$hole pulling out in front of me 2 weeks later and totaling it.
PSS: Not sure if it passes inspection. I think it does, but don't hold me to that. The better you make it look and the better it is actually done the better the chances of *legally* passing inspection. If not, there are always the "not so legal" ways to get it passed.
Old Jul 19, 2005 | 06:00 PM
daves240sx07's Avatar
Just my two cents. But if you have a rusty hole in the frame rail then there can be rust all over the car. I would check the rest of the car to see if it's just that one spot. If it's just that spot then fix it. We have alot of rust in the north east. Good luck
Old Jul 20, 2005 | 12:48 AM
nsn240's Avatar
woah... unless you are a very expierenced welder, i'd get that fixed by someone who knows what they're doing. a frame that is rusted enough to crunch through is def not a good thing...
Old Jul 20, 2005 | 06:11 PM
FUNGC's Avatar
thats a good point! haha well ima not an experienced welder or mechanic either! haha im jus a teenager that takes cars apart and puts em back together for tha fun and experience of it!
it only crunched through cuz my friend lowerd tha hydraulic jack soo fast and tha weight all fell into that one spot and it jus dented in and tah rust cracked through =\ not good.
Old Jul 21, 2005 | 12:33 AM
nsn240's Avatar
haha , either way, a rusted out frame isnt a good thing...
Old Jul 21, 2005 | 04:16 PM
FUNGC's Avatar
true true... haha well i gotta get it fixed some how =\
laos boi84
Dec 3, 2003 04:18 PM
<cartman>
Nov 30, 2003 10:48 PM
CP Racing
Nov 28, 2003 03:13 AM
CP Racing
Nov 27, 2003 09:17 AM
j-z
Nov 16, 2003 03:54 PM
