Check Engine HELP!
Check Engine HELP! (EGR #32)
OK.... What is code #32, I have a list saying it's EGR System, but what is that?.... Emissions or something?
My question is how do I fix it, and why does my check engine light only come on sometimes because of it?
edit: is the O2 sensor part of the EGR System?.... my first thought was my o2 sensor might be going bad or something... Thanks to anyone who can help me
well,,,
i have no clue what it does either but i look on here and really couldnt find anything.. but i googled it and found some background on it.
http://www.fordscorpio.co.uk/egr.htm
http://www.asashop.org/autoinc/nov97/gas.htm
http://www.carcare.org/Emission_Control/egr.shtml
just take a glance,, the last one has pictures
srry i really dont have a real answer.
Re: Check Engine HELP! (EGR #32)
The EGR valve (Exhaust Gas Recirculation valve) controls the quantity of exhaust gas to be led to the intake manifold through vertical movement of the taper valve connected to the diaphragm, to which vacuum is applied in response to the throttle valve. The EGR valve is also regulated by the BTV valve.
And yes it is a part of your emissions.
Well, I reset my ECU and the light is staying off for the moment...(crossing fingers)
Maybe this time it wont come back rearing its devil horns and annoying the hell out of me.... especially when it flashes (comes on and off as it pleases)
Anyway... Seems OK for now... THANKS
~~James~~
~~James~~
