constant blowing of the #2 "Meter" fuse.. need advise porfavor
Old Aug 18, 2005 | 03:09 PM
sirenx's Avatar
from time to time the #2 fuse.. next to last one on the left column ... would blow out. its a 10 amp fuse.. so i replaced with higher amp fuses and it works fine for a while.. it usually lasts like a couple weeks or so then blows again..
well i have had some overheating problems and have just replaced radiator cap .. water pump .. and bled my coolant system..
so i was getting ready to test out my car.. and see how if i fixed the overheating problem..
but the meter fuse now is blowin everytime i pop a fuse in.. i went up to even a 25 amp fuse and it is still blowing as soon as i turn the ignition to on position..
this meter fuse controls the power seatbelts.. a/c / heater panel .. and all the gauges in the dash except speed..
the problem is i cant test my car because my temp gauge does not work now.. and neither does my heater..(to remove air bubblers in coolant lines)
has anyone else had a problem with this fuse.. is there a simple fix other then ripping everything out and checking for shorts?
need advice so that i can get my 240 running again..
by the way.. this is a 92 240sx se ..
thanks
Old Aug 19, 2005 | 12:22 PM
sirenx's Avatar
ok.. how bout.. any tips on how to trace the wires behind the fuse box.. do i need to remove the entire fusebox to find the wires and trace them?
Old Aug 19, 2005 | 02:50 PM
2fast4y0u's Avatar
i would say that there is just a wire that is lose behing your tach or hvac system. if thats the case it is grounding out and blowing your fuse.
its probably a wire that doesnt have much around and thats why it was lasting before. you hit a bigger bump and bam. now its just touching.
have you taken anything apart lately that might have caused this to happen?
Old Aug 19, 2005 | 02:58 PM
sirenx's Avatar
i had a new audio system installed in my car a while back.. but i cant remember if this was doing that before the install or not..
i guess its possible the fudged something up install my headunit ??
Old Aug 19, 2005 | 03:06 PM
2fast4y0u's Avatar
i would definetly check
Old Aug 19, 2005 | 03:45 PM
sirenx's Avatar
do i need to take out the fuse box to expose the wires that i need to trace. or is there an easier way?
Old Aug 20, 2005 | 11:24 AM
2fast4y0u's Avatar
i wouldnt take out the fuse box at all... you are asking for problems you dont need.
240 pimpnn
SR
Jul 6, 2009 10:34 PM
Silvia20t
Sep 1, 2007 04:25 AM
SoupBA
Jul 13, 2007 05:57 PM
nautica_t
Dec 30, 2005 12:16 PM
Spazum888
Aug 11, 2003 02:29 AM
