dash lights
Old Jul 25, 2006 | 10:27 PM
dash lights
I just bought an s13 (finally!) and when I turn on the headlights the dash lights are out. I searched but what I found confused me. Maybe its cuz its late. But anyways the previous owner said they went out when he installed a new head unit. All I want to know it what wire and where is the wire? Thanks.
Old Jul 25, 2006 | 11:08 PM
re037's Avatar
check fuses, then bulbs
Old Jul 26, 2006 | 12:46 AM
It's probably a wire in the harness that just needs to be bolted to a ground, like I said in previous threads, I forget which wire it is though. Sorry, I know thats not really much help lol
Old Jul 26, 2006 | 06:40 AM
Thats what I thought to do from reading the other threads about this, but do you know where the wire might be? The guy I bought it from said the passenger side kick panel. Is it there or behind the head unit?
Old Jul 26, 2006 | 12:44 PM
anonymous_240's Avatar
i think thats a common thing for 240s because my car is like that too. although the owner LIED to me about that and said everything WAS working right. anyways its not the fuse its the wires.
Old Jul 26, 2006 | 12:48 PM
It will be behind the head unit
Old Jul 27, 2006 | 12:36 PM
daves240sx07's Avatar
I had the same problem with mine. Had power everywhere so everthing should of worked, Found that the dimmer swicth was b stuck to the lowest setting.Could not turn it up. For now I put in a bye pass wire to make it work. Hope this helps.
Eminembdg
Feb 18, 2005 03:41 PM
Eviscerator
Aug 17, 2004 05:09 PM
JonBrekke082885
May 17, 2004 07:43 PM
craigkiel
Mar 22, 2004 01:32 PM
Rynxprs
Oct 17, 2002 06:35 PM
