Difference between s13 & s14
Old Jun 26, 2004 | 11:45 AM
JeromeS13's Avatar
Originally posted by jboo88
So it was, ka24e SOHC 2.4L 12v 140hp single overhead cams 1989-1990 (first-generation motor), and then later models,
1991-1998 KA24DE DOHC 2.4L dual overhead cams155hp (mid-generation motor with not much difference in them. I see now the "S" motors were used in the Silvias. But what I was asking was would a s13 be any diff. from a s14, because I would like to swap?And what kind of turbo did a s15 have?
S motor? WTF are you talking about? The S in S13 and S14 designates the CHASSIS, as I specified above.
And, as far as the differences in the actual KA24DE engines, that is all mentioned above as well....
Old Jun 26, 2004 | 04:25 PM
ArticDragon's Avatar
Ok, time to give a big old lecture on engines and Silvias. Ok, here goes. Dont flame me for being wrong in some areas, just correct me and I'll learn too.
USDM
89-90 KA24E (Pignose s13 coupe&fastback)
-2.4 L Single Overhead Cam
-140@5600rpm
-152@4400rpm
91-present (s13 coupe+fastback & s14) KA24DE
-2.4 L Dual Overhead Cam
-155hp@5.6k rpm
-160lb/ft@4400rpm
JDM (for the sake of simplicity, only turbo engines will be discussed)
89-90 CA18DET
-1.8 L
-173hp@6400rpm
-166lb/ft@4000rpm
180SX 91 up SR20DET Redtop
-2.0 L DOHC
-203hp@6000rpm
-202lb/ft@4000rpm
S14 SR20DET Blacktop
-2.0L DOHC
-217hp@6000rpm
-202lb/ft@4800rpm
S15 SR20DET
-2.0 L DOHC
-247hp@6400rpm
-202lb/ft@4800rpm
Anyways, that's just engines. Anyways, other than engines they're slightly diff. Some S14's are 5-lug. Cams on the S13's are diff as you jus read, but parts are pretty much interchangable on engines. Hope you learn something about the engines. Theyre not S engines. S is for the chassis, S12 for the old school 200SX, s13 for 240s 98-94 models, s14 for 95-98 I believe, and s15 for the newest ones, 99-up.
Old Jul 8, 2004 | 11:11 AM
I know the "S" in s14 refurs to the chasse but you know what i mean the SR20det.
Old Jul 8, 2004 | 11:54 AM
©ä®ßöN's Avatar
what about the SR do u wanna know? Do you wanna know, the difference in the S13 and S14 SR? or if u can put a S14 SR in a S13?
Old Jul 8, 2004 | 10:02 PM
yeah, sure
Old Jul 9, 2004 | 07:34 AM
JeromeS13's Avatar
yeah, sure
www.google.com
Old Jul 9, 2004 | 06:47 PM
nice
Old Jul 9, 2004 | 10:48 PM
sr20 learner's Avatar
i have a ques. the cams in the 91 240sx r they like better then then the 95 and up 240sx cams. thanks
Old Jul 10, 2004 | 09:08 AM
JeromeS13's Avatar
Wow.... I'm amazed at how people reply to a thread without reading the entire thing.... Are you guys just lazy, or just too ignorant to know how/where to read or do research?
Have a nice day....
Old Jul 10, 2004 | 11:05 AM
Originally posted by JeromeS13
S13 designates a chassis, not an engine. The S13 is the USDM Nissan 240sx from 89-94. Now, there are 3 different engines.. A 140hp SOHC KA24E from 1989-1990. In 1991, they came with a 155hp, 160lb/ft of torque KA24DE. Now, the cams that everyone wants are the same from 1991 on into part of the production year of 1993. In 1995 they did change the engine slightly. They put a different head on it and tuned down the cams a bit. Also, they put a different alternator on it. In 1996, they changed some emissions equipment and made the engine OBD-II compliant. That means, they changed a lot of the sensors and MORE vacuum lines.
The engines from 91+ are all interchangeable with little-no modifications...
Any questions?
Dude, the cam question was answered on the first page. Read through the thread at least so that way questions aren't repeated and you aren't flamed for asking something that's already been answered.
Old Jul 20, 2004 | 10:09 AM
  #26
Old Jul 21, 2004 | 12:31 AM
  #27
RealDS13's Avatar
Wouldn't it be sick if Nissan dealers brought out the s15 here in the states?!?!? I know it might have the ka24de engine but perhaps a custom turbo setup? I dunno about u guys but that would put a rise in my pants LOL!
Old Jul 21, 2004 | 07:22 AM
  #28
That would be awsome!!
Old Jul 21, 2004 | 12:27 PM
  #29
Not gonna happen
Old Jul 21, 2004 | 02:02 PM
  #30
y not?
