double crank noise?
double crank noise?
has anyone ever heard ur car double crank? when the can is one already and u try starting it again? i get the noise all the time and its the first time i start my car. i have to give it a couple good tries to get it running. can anyone tell me wat the problem is? and how i can fix it? thanx
when ever i try to start my car it tends to have a double crank.. the noise when you have ur car running and u try to start it again.???? that loud crack noise..?? am i makin anysense? its hard to explain.
you might want to pull out your starter, you might be missing some teeth from it. it is also very cheap to get ur starter checked. i don't think it could be anything with your ignition wiring. also, try to explain a little easier.
