Drive trouble can it be the spark cables
Old Aug 26, 2007 | 05:46 PM
Jay_240sx's Avatar
Ok well today i bought new spark plugs and before i changed the plugs the car would turn on but i had to rev a little for it to turn on complety .. but in the process of changin the spark plugs i found 2 of the spark cables are broken that the plug wasnt even gettin juice.. so wat im wonderin is can that be y its not stayin on while in drive?? (like i put it into drive and it starts to shake alot and starts tryna shut off) or should i still get the maf checked...
Old Aug 26, 2007 | 06:18 PM
dude if you see ANY sign of breakage in the wires. get them out of there.. electrical current will find any way out and you will arc off the valve cover.. and your car will run like a lawnmower
Old Aug 26, 2007 | 07:02 PM
Jay_240sx's Avatar
I mean the cable itself isnt broken im talkin about the part that connects to the spark plug is broken inside the "boot".. and i also want to kno if i try start to start the car with only 2 spark plugs would it 1 turn on and 2 mess it up in any way??
Old Aug 26, 2007 | 09:29 PM
acfalconhawk's Avatar
Yeah, do be careful about that. My buddy's radiator fan cut one of his plug wires in half (fwd buick) i mistakenly was resting my hand on the fender and grabbed the wire..."DDDDDDDDDDD" "Whooooaaaaa!!!!" I bridged the circut
back on topic... if any cylinder is not sparking then yeah it will run like ***. every autotragic i have driven when you put it in drive the rpms drop. but with cylinders not sparking it gets to that point where centripetal acceleration of the crankshaft slows down...(in english: the engine is turning to slow to continue to rotate).
Old Aug 27, 2007 | 12:21 PM
LA_phantom_240's Avatar
Don't diss the autotragic trannies!
... I have yet to convert the 'vert to a stick. lol.
Anyway, go ahead and replace the wires. They're not expensive, and any kind of wear and tear could lead to bigger problems. Also, clean the IACV and run some seafoam through the car. Also, change the o2 sensor. Between the IACV and o2 sensor I have noticed a drastic change in the way my car runs.
A word of caution though; buy an o2 sensor socket... our cars DEFINATELY need it or you'll be spending a lot longer than needed changing it. It takes like 5 mins to do with the socket.
Old Aug 27, 2007 | 05:43 PM
Jay_240sx's Avatar
ight thanks for the advice dude
s14Drifter
Sep 28, 2008 11:17 AM
rancidnsx
Oct 31, 2005 01:58 PM
l2aine
Jun 21, 2005 10:04 AM
slo9012Vde
Oct 4, 2004 11:35 PM
NISMOVA
Jun 14, 2004 09:54 PM
