dumb question
dumb question
okay, i am selling my 5 lug hubs and spindles, and i got everything off fine, i jsut cant figure out how to remove the damn rotors. i know they haev a 30 mm nut with a cotter pin, (front rotors), but thats under a little cap thingy, and i cant figure out how to get that off... lol.
so basically, how do you get the rotor cap thing off?
i was looking at the hub "cap" thingy, and you can see it with the rotors on. and i couldnt get the rotors off, so i figured the cap had to be removed. so the fronts just come right off too..? my rears practically fell off... these are stuck.
There should be two holes on the rotor where you can screw in two bolts. The bolts will push against the hub and the rotors will come off. These holes are there for removing rusted and stuck on rotors. If your rotors don't have these holes tap then with a rubber mallet from behind after spraying the back with some rust penetrater.
