e brake problem
Old Nov 8, 2007 | 07:57 PM
s13owner's Avatar
e brake problem
tryed to readjusted my e brake and still dosent work. there is no tension at all on the rear brakes.
Old Nov 8, 2007 | 10:47 PM
The cable could be snapped.
Old Nov 9, 2007 | 05:37 AM
s13owner's Avatar
well this is the thing if you pull up on the e brake. it will some what hold the driver side wheel some what will not hold the passenger wheel at all.
Old Nov 9, 2007 | 06:14 AM
you have to remember your whole brake system is almost 20yrs old. Tight cable wont always lock up worn out calipers,rotors and pads. that might be something to think about, unless of course you already replaced those.
Old Nov 9, 2007 | 09:56 AM
IIRC the cable splits in two at the rear axle. Maybe it broke after the split on the passenger side.
Old Nov 9, 2007 | 02:40 PM
hayabusa03rx's Avatar
They are more than likely stretched. Its not a hard swap to do. I had to do it to mine, turns out that the part from the ebrake handle to the T is the stretched part.
uvamosk
Aug 12, 2005 07:31 PM
jdmsoarer
Apr 17, 2004 10:59 AM
jdmsoarer
Apr 6, 2004 05:56 PM
SlydeSHO
Jan 22, 2004 04:20 AM
dkdeleon
Nov 14, 2002 11:33 AM
