Brights Don't Work
Brights Don't Work
I know this is kinda random but my passenger side bright doesnt work, the low work but the bright doesnt i replaced both headlights and the one bright still doesnt work any ideas
thanks
thanks
it could just be the switch. same thing happened to me, first the passenger bright went out, then the driver's side went out. its really easy to install a new headlight switch, but really expensive ($80)!!
hi, new to club240, but 240 lover none the less. my passenger side high beam doesn't work either. i went to get my inspecton done and they replaced my headlight and gave me the inspection and it still doesn't work. i don't know why either. i'll worry about next year when inspection comes up again. ha ha.
the headlight switch is the combination light/turn signal switch mounted on the column. 4 screws to take off the plastic column cover, 2 screws hold in the headlight switch, and iirc 2 wire connections. its really easy to do. 2 or 3 minutes.
Christpher
May 6, 2006 08:57 PM
