EGR Question
Old Aug 4, 2007 | 11:42 PM
Rnz520's Avatar
EGR Question
When you remove the EGR, does it throw a CEL?
Also, is it worth it, does it really free up power?
And last, where can i get a block off plate?
Any info appreciated. Thanks
Old Aug 5, 2007 | 01:12 AM
s14 yes
s13 no
also if you have CA model double yes
and its free's up a bit, but you will not notice much
Old Aug 5, 2007 | 06:41 PM
Rnz520's Avatar
ok, and where can i get block off plate?
Old Aug 6, 2007 | 06:29 AM
240AM's Avatar
EBay last time I checked. I think it is the same guy that makes the central vent gauge pod.
Old Aug 6, 2007 | 03:56 PM
DALAZ_68's Avatar
do wut i did
un bolt both ends of the egr pipe...and block em with nickles (as in a 5 cents) the fit nice and snug on each end, then just rebolt the ends...u can just hack off the rest of the pipe
no recirculating exaust for u...
and i do thin itll throw a cell...obviously i would assume
Old Aug 6, 2007 | 04:37 PM
thatloserkidqui's Avatar
people mainly take them out to get **** out of the way in the engine bay...no real power gains
Old Aug 8, 2007 | 11:22 PM
DALAZ_68's Avatar
true
mainly reason i did it for mine cuz i was swapping a DOHC from 95 into my bay.. just gave a lil more room to work with nothing more
ur car will take a bit longer to warm up since ur not recirculating hot air thouhg
just a thought if u live in cold weather
Old Aug 9, 2007 | 12:42 AM
my_kinda_livin's Avatar
it shouldnt make much difference though, should it? ive had mine plugged for a while and the engine still warms up fast in cold weather
Old Aug 9, 2007 | 12:30 PM
DALAZ_68's Avatar
im just repeating wut someone else stated to me
i wouldnt ever knoe
gotta love Cali weather
Old Aug 9, 2007 | 01:28 PM
yeah, it may be different for someone else since cold weather to me is in the 40s =P weather is one of the the only reasons i would stay in cali
Old Aug 9, 2007 | 02:09 PM
Enlefo's Avatar
I have my EGR blocked off with a plate, it will throw a code unless you solder resistors into the circuit to trick the ECU into thinking everything is fine. I had a hard time finding a block off plate, bought one off a forum from some guy for $20 then had my friend make a few extra with the plasma cutter at his work. PM me if you want one I'd be happy to sell one to ya for cheap. Oh and it gives a dynoed 8hp in the top end on the s14... I definantly noticed a bit more HP on the top end and TQ throughout the mid range and top. You'll want to have some way of tuning your fuel if you do this though as it will make you run way rich on the bottom end. I'm running about -8% to -13% with an SAFC2 and I have intake, header, high flow cat and cat back. Hope this helps!
MasterOSkillio
Dec 31, 2009 11:38 AM
slowpokee
SR
May 31, 2008 12:54 PM
zmarquese
Jun 19, 2006 08:46 PM
Enlefo
Oct 22, 2005 11:41 PM
brooksmosher
Jan 13, 2004 11:23 AM
