Engine light goes on and off??? is it suppose to do that?
Old Jul 8, 2006 | 01:16 AM
jackyliem's Avatar
Couple days ago my engine light suddenly turned on so I pull the code from the ECU and it said my fuel injector leak and there is problem with the ignition wiring. First, I found that there is a loose wiring with my MSD so I fix that right away. Then I took the fuel injectors out and soak it into SeaFoam (just some cleaner stuff if you dont' know what it is). After that, I installed the injectors back in to it.
After driving about five miles my engine light turned off (so I was woohoo, I fix the problem) but today the engine light is on again.
The question is. If the problem is fixed, should the engine light go out by itself? so is my problem fixed or not?
Old Jul 8, 2006 | 04:19 PM
re037's Avatar
you resetted the ecu right?
Old Jul 12, 2006 | 02:06 PM
Badazz_240's Avatar
Check your ECU.... I had this problem, and it was because my little screw (the one you use for diagnostics) was turned all the way in the wrong direction (my own fault....)
Anyway.... that seemed to fix it for me
Old Jul 14, 2006 | 07:42 PM
jackyliem's Avatar
hmmm I just put two fuel injector cleaner and the light go out again but this the my gas mileage is fixed. so I guess the light will go out by itself if the problem is fixed. thanks for the help guys
Old Jul 14, 2006 | 08:03 PM
i would pull the code(s) and just see if its something thats a real easy fix
Old Jul 14, 2006 | 09:33 PM
jackyliem's Avatar
yea I will do that soon too.
Old Jul 17, 2006 | 03:58 PM
nightkid86's Avatar
Once you reset the ECU doesn't it take it a little while before it starts saying codes again?
Also are you getting a code 55?
Old Jul 17, 2006 | 09:47 PM
nsn240's Avatar
maybe a couple key turns and a little driving, but it doesnt take very long. Yes, and code 55 would be a good thing (Im hoping 55 is the "nothing is wrong code" im thinking it is)
Old Jul 18, 2006 | 10:39 AM
Badazz_240's Avatar
^^^ yeah it is
jackyliem
May 17, 2005 07:21 PM
98cwitr
Apr 16, 2005 10:40 PM
Jedi Mind Gamez
Sep 18, 2004 07:03 PM
sleighty
Apr 8, 2004 11:31 AM
kerv
Aug 7, 2002 04:12 PM
