FAILED CALI SMOG... Need Help
Old May 3, 2005 | 05:42 PM
rb26dett's Avatar
Okay my 91 240 just failed california smog. It passes everything but NOX... The Maximum Allowable Emmisions at 15mph is 799 and 25mph 738 and the Gross Polluter Limits is 2002 at 15mph and 1802 at 25mph. The car is putting out 4964ppm at 15mph and 4952ppm at 25mph... The guy said it might be a bad EGR or CAT... Anybody have any ideas to help me out? Cause i dont want to spend alot of $ having a shop check it out when it might be something simple i could fix...
Thanks
Old May 3, 2005 | 07:56 PM
needa240's Avatar
its probably the fact that you have an rb26dett in your car.
Old May 3, 2005 | 09:18 PM
rb26dett's Avatar
lol i dont have a rb26 ahhaha... i still have the stock ka24de
Old May 3, 2005 | 09:24 PM
BigVinnie's Avatar
What I would do is an ecu/engine diagnostic check. If that isn't the problem then I would do a full electrical tune up it might be that simple.
My NOX emission was runnin high because I had bad spark plugs, and even though my ecu wasn't reading the O2 sensor I found out that it was bad also............
I've seen cars pass the cali smog with popped out CATS, I dought it is the CAT, and if the diagnostic doesn't read the the EGR/BPT, then the EGR/BPT isn't the problem........
Old May 3, 2005 | 09:33 PM
rb26dett's Avatar
how much do shops normally charge for a diagnostic check? cause i dont have a check engine light... and i was planning on doing seafoam, new plugs, and new oil anyways... but i dont think thats the only problem causing it to be near 5000ppm?
Old May 3, 2005 | 09:53 PM
ryoisaguri's Avatar
praise the lord i live in alabama
Old May 3, 2005 | 10:02 PM
BigVinnie's Avatar
You can buy an ACTRON code scanner book for about $30, or buy the ACTRON scanner for $150........
When the plugs don't burn fuel, your engine will run rich.......
It has also been tested and proven that an O2 sensor only runs at about 1/2 efficiency after 6000miles, the ecu won't pick up the O2 as a bad sensor ubntil it doesn't work at all, meaning that the signal is cut short......
Old May 3, 2005 | 10:37 PM
LTSCUDRFT's Avatar
Run your codes.
this should help>
http://www.club240.com/forums/showth...threadid=22144
Old May 4, 2005 | 12:23 AM
jackyliem's Avatar
well I heard the airpump doesn't do much but it will be a good idea to check that.
Old May 4, 2005 | 11:22 AM
Fast1One's Avatar
Stop Showing off Biotch! Ha Ha J/K
Old May 5, 2005 | 03:02 PM
calidrifter's Avatar
Nissans are notoriuos for the bad EGR so it probably is that since it isn't recirculating the spent emissions. I had almost the same issue 2 yrs. ago but I barely got under the allowed #. A cheap trick to pass it would be to change the oil right before you go for the test since that alone carries a lot of pollutants.
Old May 11, 2005 | 05:18 PM
LA_phantom_240's Avatar
praise the lord... i live in louisiana lol
woofywolfer
Oct 9, 2008 04:36 PM
T.C
Aug 8, 2006 09:50 PM
Driftin_24O
Feb 9, 2004 07:24 PM
ryan15
Jan 25, 2004 08:12 AM
BayArea240sx
Feb 11, 2003 11:06 AM
