Gauge Swaps
Old Apr 2, 2008 | 09:45 PM
Alkaemy's Avatar
Gauge Swaps
I'm wanting to switch out my standard cluster with after market mechanical gauges in my 89 240sx. has anyone done this successfully and put in a speedometer cable for the mechanical gauges. Seeing as this car normally uses electronic speed sensors, i need either an adapter or a speedometer cable built for this car. If anyone knows where i can get either of these, please respond.
Old Apr 3, 2008 | 01:36 AM
well its a bad idea because you are not suppose to mount liquid mechanical gauges inside of a car..
yes if you wanted to run a mechanical speedo.. you would have to do some googling because no one does that.. the signal is electronic.. and mechanical speedo has a cable that runs from the tranny to the back of the cluster.. your best bet would be to look up old nissans that use a cable but has a transmission speed sender thats a style like the KA.
if its the vintage look that you want, they have vintage electronic gauges.
Old Apr 3, 2008 | 02:04 AM
Alkaemy's Avatar
the vintage look is one i was looking for, however the exact gauge style i found does not offer an electronic speedo thats i've seen so far, its the iequus 7000 chrome series. hum...this might be fun, i'm currently seeing if i can have a shop custom make me one, i'll post any results from that. any other info will be appreciated.
Old Apr 3, 2008 | 02:07 AM
Alkaemy's Avatar
btw, what turbo did you put on your KA and is it e or de
Old Apr 3, 2008 | 02:54 AM
im my turbo life time.. i have had
Xs power T3
z31 T3
and current turbo that will stay with my set up is a Holset H1c from a 94 dodge ram
check out the KA-t Section for more specs.
all of my motors were KAde except for the first factory one.
Old Apr 3, 2008 | 02:55 AM
Alkaemy's Avatar
ah ok, thanks
Old Apr 3, 2008 | 02:59 AM
no problem bro..... glad i could help
Old Apr 3, 2008 | 03:26 AM
yarou's Avatar
the mk2 s12's (1986 and after) used the same C trannies as the KA and had a mechanical cable. You can try sourcing one from those
Old Apr 3, 2008 | 04:24 AM
yay..... your saved
Old Apr 3, 2008 | 05:19 AM
Alkaemy's Avatar
freakin a man, you guys rock, just go t back from burnin some rubber in my non speedo'ed 240sx
lol
thnx guys
Old Apr 3, 2008 | 05:23 AM
Alkaemy's Avatar
wait, the s12 is the 200sx right?
Old Apr 3, 2008 | 08:45 PM
Alkaemy's Avatar
hehe
problem solved, i'm just gonna get these
http://autometer.com/demos/nexus/
topsecretgold
Aug 4, 2005 10:31 PM
240sxSleeper
May 24, 2005 12:30 PM
Rynxprs
Mid Atlantic
Oct 21, 2002 09:32 AM
canadian240
Sep 25, 2002 02:49 PM
Koua Jones
Southeast
Sep 24, 2002 05:51 PM
