Which Gauges First
Old Nov 8, 2005 | 05:50 PM
nsn240's Avatar
Which Gauges First
Going With Defi BF Gauges and the necessary Control Unit...
Here's the line-up
1. Boost/ Vacuum
2. Oil Pressure
3. Water Temperature
Then
4. Exhaust Gas Temperature
Anyone Know where to get a good price on these?
Old Nov 9, 2005 | 05:27 AM
ogee-s13's Avatar
I thought you already bought gauges??
Old Nov 9, 2005 | 02:26 PM
GrahamH's Avatar
I would get the oil pressure first.
No oil pressure=blown motor
Old Nov 9, 2005 | 04:13 PM
I believe the toss up is between the EGT and the Water Temp gauge, sounds like he has the others or is positive on getting them.
Old Nov 9, 2005 | 04:23 PM
Helghast's Avatar
EGT first.
Boost at high EGT Temp = BYE BYE TURBO!
Old Nov 9, 2005 | 06:22 PM
silviasichigo's Avatar
I have the whole Defi Line up, I bought them all at the same time and that was Almost $3000 for everything. I would say get the TEMP Guages 1st for they are the most expensive of the set. Once you start knocking out the expensive ones then the Cheap ones won't seem so bad. I say this because if you are buying guages obviously (to me) you don't have guages and they are not going to make your car faster or run better but once you have all the guages in you can better tune the car and monitor its vital signs a little better, and Defi are the best guages I have used. So what you buy at this point is not really that important since you have gone this long with out guages (minus the stock ones which are ok to a point)
Old Nov 9, 2005 | 06:26 PM
nsn240's Avatar
Originally posted by Helghast
EGT first.
thats cause High EGT means you are running lean...
Old Nov 10, 2005 | 02:39 PM
EGT. And get something besides DEFI, only idiots pay that much for gauges on a street car LOL
Old Nov 10, 2005 | 04:53 PM
Helghast's Avatar
Get Greddy.
I'm rocking all 52mm Greddy Guages.
Old Nov 14, 2005 | 07:28 AM
get-the-drift's Avatar
lubrication is everything!!! ill get the oil presure first
Old Nov 14, 2005 | 09:39 AM
*Tx_BLooD_240*'s Avatar
glowshift.com my brother got some nice ones of there.
Old Nov 14, 2005 | 09:43 AM
Zephyr's Avatar
Greddy is cheaper....
I only thought about buying two gauges, boost and oil temp. Boost since im SR and oil temp basically to watch the oil temp from the turbo. Id figure if the temp gauge on my cluster starts moving then theres a problem and I'd better pull over, so I dont need water temp, and Id figure oil pressure wont be needed since if there is no oil pressure, you're kinda not going anywhere.
Old Nov 14, 2005 | 11:53 AM
Re: Which Gauges First
Here's the line-up
1. Boost/ Vacuum
2. Oil Pressure
Then
If you're going Defi, your not going to really find good prices...their prices are pretty high everywhere for their products.
nsn240
Aug 30, 2005 05:10 PM
1995 240sx
Jul 30, 2005 01:40 PM
d4vech3n
Jan 5, 2005 08:19 PM
polishmafia4u
Nov 8, 2003 05:55 AM
Tahoe
Oct 18, 2003 03:53 AM
