gauges took a vacation
Old May 4, 2006 | 07:36 AM
gubermyster's Avatar
so i started up my car the other night, hopped in and noticed it was darker than ussually
so definatly tried to get to the gauges but goddam you have to take the whole dash out? the speedometer still works(when it feels like it) and only the clock and the check lights light up
and if i got the white-face replacements they still wouldn't work correct? one of my friends said the white face gauges have there own wiring
but anyways anybody have any experiences like this? thanks
Old May 4, 2006 | 08:06 AM
ReigH's Avatar
bulbs went out?
Old May 4, 2006 | 09:09 AM
To replace the bulbs you have to remove the panel under the drivers side dash, drop the steering column down a little bit, and then you can pop out the cluster and bezel. It's not that hard. Did you check fuses as well? Also did you mess with any wiring before this happened?
Old May 4, 2006 | 07:40 PM
yea but everytime i try to take of the panel with the healight button and defrost and all htat stuff it hits the level that moves the steering wheel, and i dont think i did mess with anything, but im always finagling with my car so maybe something mighta happend mighta knocked something loose, but its rainy out tonight so ill have to deal wiht it tommorrow, but ill check agian, thanks,
Old May 5, 2006 | 12:58 AM
Thats why you take the two bolts out that hold the steering column near the top. It will allow you to drop it down enough to pull out the bezel. Also, by messing with wires I mean did you mess with anything like stereo wires or something of that sort?
Old May 5, 2006 | 10:26 PM
yea i had messed with my stero wires, you think it shorted it out?
Old May 6, 2006 | 09:30 AM
Similar thing happened to my friend before after he was messing with his stereo wiring. To fix it he had to ground one of the wires, I just don't remember which one off the top of my head. Once he did that everything worked again.
Old May 10, 2006 | 09:30 AM
well they started working again after not touching them so i dunno
Amolao
Aug 2, 2005 11:56 PM
Sil40_Mayhem
Oct 30, 2003 11:22 AM
DrftDmn
Jun 24, 2003 07:57 AM
