Turning signals....
Old Oct 20, 2005 | 05:44 PM
GodGiven315's Avatar
Turning signals....
Hi guys, i have a 1992 240sx and my right turning signal doesnt come on when i turn on my lights. They only turn on when i put the turning signal or when I put the hazard lights on. I just put in new bulbes on both sides with new connectors and changed the fuses and relays... anyone have any ideas? I was also wondering if its possible to make the lights stay shining as bright as when u put the hazard lights on cuz they shine really bright. Thanks
Old Oct 22, 2005 | 03:21 AM
reefer1114's Avatar
are you sure you bought the right bulbs? check the back of the light where the bulb screws into...compare it to the bottom of the bulb, is it the same type? if not you have the wrond bulb/s. sometimes its the simple things, but this is just my gues...
Old Oct 22, 2005 | 01:55 PM
Cape 240's Avatar
Could be a wire or a fuse.
I doubt not having the correct bulb would make this happen.
Some type of relay issue somewhere.
2plus4plus0EQ6
Dec 23, 2006 02:13 PM
wasaabi4784
Sep 4, 2006 05:39 PM
ryan15
Jan 28, 2004 10:59 AM
ixcocoyxi
Sep 12, 2003 11:42 AM
Monkey Boy
Sep 8, 2003 08:11 PM
