Help - got dicked by Mechanic !!! coolant sensor ?
Old Dec 10, 2003 | 03:41 PM
drifterswanted's Avatar
Angry Help - got dicked by Mechanic !!! coolant sensor ?
took my car in for the slave cyclnder, $140 ended up ($650) -
new slave- new master cylnder and some ball joint inside
transmission and to top it off now my car runs like **** and
The cluthc is worse, i have to put the pedal to the floor to
get in firt..... I am so pissed i am sick to my stomach
anyway need to get this sorted out...
Can some one tell me were the colant sensor is
on a 91 240sx. I am now not getting any reading on my
temp gauge but when was working it would go down
when i am on the gas and accelerating...
My car is idling like crap and sound like its popping when i am
comming off the gas... It is running like poop, i even tried to really
get on it and it felt like my gsxr when it needed the carbs redone--
the acceleration was breaking up around 7,000rpm.
thx,J
Old Dec 10, 2003 | 05:09 PM
Drift-Obsession's Avatar
7k rpm? isnt the redline around 6500?
IMO generally when you take the car in to get the clutch fixed it isnt suppose to affect the engine at all.
what exacty is your question? "what is causing all thease problems?"
Old Dec 10, 2003 | 05:24 PM
kramsuey2268's Avatar
ur suzuki at 7k rpm's right ? When I replaced my clutch I had to mess with the clutch pedal adjustments, becuase I had to push the pedal all the way to the floor to shift and the clutch was slipping a bit. I ajusted the master cylinder rod first and then adjusted the clutch pedal stopper. All this is done from inside the car. The transmission sounded a bit rough at first but after about a couple of hours of driving its like brand new.
Old Dec 10, 2003 | 06:09 PM
sorry if my post was all over the place i was just so pissed.
I need to find the colant sensor, i am not gettting any reading on
it my temp gage reads nothing
.... I have heard that may be the idle and
acceleration
problem.
Old Dec 10, 2003 | 06:48 PM
irax's Avatar
check all the vacume tubes for the intake, there could be a cracked tube or something
DriftX
May 27, 2007 01:52 PM
honorcode3
May 13, 2007 07:04 PM
j1n
Jul 30, 2004 06:31 AM
DCTperformance
Jun 10, 2003 03:40 PM
Driftin180SX
Mar 6, 2002 03:20 PM
