help with grinding engine
Old Mar 14, 2005 | 05:55 PM
jptech's Avatar
whenver i start my car, for like a second there is this grinding noise. it sounds normal when the starter is cranking the engine, but right when it starts it makes this loud grinding noise, and then its normal again. does anyone know whats up?
Old Mar 14, 2005 | 08:31 PM
jbayles's Avatar
Hard to diagnose without hearing the noise but first impressions:
Your holding the key in the start position too long
or
You don't have the starter's pinion gear lash adjustment correct(if there is one)
or
the pinion is worn/damaged and is slipping/grinding somehow
or
something in(or connected to) the hold coil that forces the starter pinion to engage the flywheel, is holding the pinion(usually your fingers ) in mesch longer than desired.
Old Mar 15, 2005 | 06:00 AM
dacheat's Avatar
I second jbayles's opinion on that. If I were you I'd pull the starter and test the pinion to make sure it's working properly. It's been a long time since I've had to do that, but I think autozone could test it for you.
oceanblue_1128
Jan 21, 2006 11:26 PM
james_s14
Jan 24, 2005 07:50 PM
epoxy
Jan 30, 2004 12:12 AM
ryan15
Jan 28, 2004 10:59 AM
Tex
Dec 13, 2003 09:55 AM
