Help With Headlight Switch Please!
Old Feb 1, 2006 | 02:57 PM
Recon2006's Avatar
Hey, i am wondering how u dissconect the headlight switch from the wire in the back? I cant figure it out, i wish it was just like the other ones were u press the button and it comes out. Please help me out on this!
Old Feb 1, 2006 | 04:20 PM
need more clear info. what exactly do u wanna do. take ur time man lol
Old Feb 1, 2006 | 04:25 PM
Assuming you're talking about an s13 and the switch on the gauge bezel. Just pull the button out, should pop right out with a nice little tug, and its just a basic clip, I forget if its one button you have to push in or if its two (one on each side of the connector).
Old Feb 1, 2006 | 04:39 PM
Recon2006's Avatar
Yea i got a 89. Ok lemme specify here since i gave like no info before haha. I jus installed some glow gauges. And i took the bezel with all the switches off, cluster and so forth. Well on the bezel you have all the switches for flashers, rear def. cruise, headlights up/down, etc. Well all of the switches on that bezel were the simple push the clip and pull and the wire comes out of the back of it. Well on the headlight switch after pulling it out of the bezel i noticed the wire had a different connector on it than the rest. By this i mean instead of having that button to push it had something wierd like a smaller button i guess i could describe it as. Well no matter how hard i push, pull, twist, and bend it the wires will not come out of the switch so i can take it off. This is what i need help on. Please any help will be GREATLY appreciated. If you dont know what im talking about and you got a S13, go outside and pop ur headlight switch outta the bezel and look at how the wires are connected to it, see if you can figure out how to take them off and get back to me.
Old Feb 1, 2006 | 04:48 PM
take a pair of pliers, and squezz the release botton, u are not weak man lol. they are just a ***** to push with ur fingers sometimes,
Old Feb 1, 2006 | 04:57 PM
Recon2006's Avatar
thats what i mean tho, it has like no release button, its a diff setup then every other switch
k_wakasugi
Mar 17, 2008 07:09 PM
CNDC
Sep 18, 2006 10:03 PM
SittnSidewayz
Mar 13, 2006 02:25 PM
Topless
Apr 6, 2005 02:09 PM
chansuifei
Mar 18, 2005 04:43 PM
