HELP, My car is shaking like a earth quake!!!
I got a ka24e and today it just started shaking like crazy. It shakes when I am park and when I take off. The idle is a at 900 rpm's and it used to be at 750 before it started shaking. Please help bacause its my only ride to work. Could it be my timing? or bad plugs? or motor mounts?
Okay I figures it out and this might help a lot....first I did the whole cap rotor and plug thing, it still was idling like booboo. Then I said let me try that stuff called "Sea Foam", I put it in the brake booster vacuum line and presto- my car problems were cured. Thank sea foam
It cost only $5.00 and yes its a injector, valve, ring, engine, fuel stablizer cleaner. My borother and I just added some to his turbo mr2 20 mins ago and its pulls harder. Its like a mechanical miracle!!! go searce "sea foam" and check out the one on sea foam wonders.
