Help takiing off gauge cluster
Old Feb 10, 2004 | 09:31 PM
ryan15's Avatar
Question Help takiing off gauge cluster
Yea I need help taking it off, it seems tha the tilt steering adjust is getting in the way, Keep in mind I did not take the steering wheel off, in the chilton maunual it shows some kind of puller to toake off the steering wheel, can I purchase one at the car parts store and if show how much would it cost? I really need help taking this off, Im getting a new cluster in the mail anyday now.
Ryan
Old Feb 10, 2004 | 09:34 PM
To take off the steering wheel you do not need a steering wheel puller, it might be easier to do it with the puller but I did it by myself...and Im pretty damn puny. Use a lot of WD 40 and man power
Old Feb 10, 2004 | 09:40 PM
ryan15's Avatar
im scared if I pull it to hard it will fly up and hit me in the face lol
Ryan
Old Feb 10, 2004 | 11:43 PM
Ryan
Lol, put on a helmet. I kicked my steering wheel off...
Old Feb 11, 2004 | 02:03 AM
Couldn't you just drop the steering column without messing with taking the steering wheel off? On S14's the cluster will pop out with some trickery, but I remember seeing something on S13's about dropping the column...
Old Feb 11, 2004 | 02:28 AM
If you want to use a puller though, you could go to a store like autozone, you can rent out tools from there
Old Feb 14, 2004 | 01:04 AM
ixcocoyxi's Avatar
wiggle it out.. and yeah.. wear a helmet..
Old Feb 18, 2004 | 09:47 AM
anubis's Avatar
you need to drop the underdash, its like 6 or 8 bolts.
undo the steering column cover that goes over the blinker switch and wiper switch, i think its four screws or bolts.
undo the four bolts from the steering column to the body. undo the back ones first. it'll make it a tad bit easier.
undo the two screws on the cluster bezel, a stubby works best.
and then there are three screws holding in the cluster i believe. one on top middle and two on the bottom side.
and then if yuou still cant get the cluster out...just poke yourself in the eye.
Old Feb 19, 2004 | 02:02 PM
ryan15's Avatar
I hate trying to take off the stupid trim its such a hassle with the tilt steering paddle and I dont think there is any way to take it off, My speedo works sometimes, the new one that i installed, I started it this morning and it auto matically said I was going 45 mph hwat the heck is uo with that?
Ryan
Old Feb 20, 2004 | 09:36 AM
Ryan
That my friend is the reason why you always leave panels off when you replace stuff, and test drive it for a day or two to make sure everything is working
NismoStoner
Apr 8, 2009 11:54 AM
Koukidough
Feb 16, 2006 07:54 PM
accel junky
Oct 5, 2005 08:37 AM
Amolao
Aug 12, 2004 09:35 AM
nisno
Aug 30, 2003 11:26 PM
