how can i make the s13 well balanced for road racing?
i want my car to be more balanced for road racing but i dont know how to make it that way. my car understeers toooooo much. should i put more weight in the trunk or take away weight from the middle like the seats? sorry if im wrong.
Coilovers, sway bars, etc...
The main goal is to keep as much rubber on the road as possible.
You want as wide tires as is reasonable, and you want the tires to stay as flat to the ground as possible at all times....
This means aftermarket pillowball mount suspension pieces
Tie rods, toe rods, traction rods, rear camber arms, tension rods, sway bars, etc.
Other than that, there is only so much you can do to shift weight around from front to rear
definately coilovers with some dampening and camber adjustment...up the stickyness of the tires in the front while leaving the rears the same..lose front sway bar...any of that would help, also adjustments such as camber, caster, and toe can all play a major roll
I agree.....like DRIFTFREEK, I have Tanabe sways....
The thing is, the increase in the front sway over OEM is only like 2mm, but the rear sway is like 2x as thick as OEM
For me, that was the mod that made my car go from understeer to almost neutral...
jspaeth!! so u have tanabes and u have almost no understeer??? wtf!! how, cuz when i autox i understeer like a ****!! i thought i need better tires which i do, but i thought i need something else. i really need to fix my understeer cuz this guy with a moded 03' mitsubishi eclipse(fwd, 250hp+) wants to race me( my ka has 170hp) in the downhill and the only way to beat him would be if i take the corners much faster than him since there arent many straights... so please guys help me!!!i wanna beat him
oh is there a way to adjust my tanabe sway bars???
