How do you Wire up the horn button?
I was a bit anxious to just get the wheel in and didn't bother trying to wire up the horn. It's been a few months with no horn and I think it''s getting annoying not having it in certain situations. Is it just about the ring making contact?
First is this your stock steering wheel or not?
If it is, there should be a black wire that is or was attached to your center piece of the wheel (horn) touch that wire to the little brass looking ring in the middle of the wheel. Take the wire off of the brass ring. If it is an aftermarket steering wheel take the two wires and attach them to the horn button on the aftermarket wheel, If your horn is going off like crazy push the button and if it stops then the wires are backwards, so switch them and you should be done.
