How to install Driverside Window on 96 240?
Old Dec 18, 2003 | 11:01 AM
ass15's Avatar
Unhappy How to install Driverside Window on 96 240?
2 weeks ago somebody broke the driver side of my car window ! and i have finally bought the window ....
but when i opened the door side panel it seemed confusing and i really don't want to start doing something that i don't know about and also i don't want to accidently break my window in the process ! i don't mind getting the shop to install it but they don't offer Warenty if it breaks !
Pls help !
thanks in advance !
Old Dec 18, 2003 | 12:05 PM
drnovascotia's Avatar
moving to general forum, FAQ's are for stuff Mods deem asked enough that they should be here.
Old Dec 22, 2003 | 08:47 AM
Drift-Obsession's Avatar
you can do it 2 ways:
1. taking out the motor for the power windows as well.
take off the panel and remove the plastic covering (if its still there) there should be 4 13mm nuts on the top and bottom, make sure the window is all the way up.undo those nuts and screw the studs in clockwise, disconnect the power cable. than there should be 1 philips screw holding the rubber molding on the other side undo that and pull it off. than push the whole unit away from the carn and the studs should come out of the holes. remove the 2 stoppers on the glass, if they are still there witha 10mm i belive. then take the unit out as one piece. there should be 3 10mm nuts attached to what leffed of the window remove those and transfer the whole thing onto the new window. re install the same way you took it out. just dont do anything violent, if i has trouble comming out or not going in look and see what is preventing it from doing so.
2. the second way is to put the window about 3/4 of the way and undoo the 4 10mm nuts holding the glass or what left of it in, take off the 2 stoppers wiht a 10mm, remove the 2 stud pairs and pull the glass out. than reinsert the new glass and line upthe holes on the window with the studs , once thats secured install the 2 stoppers and your good to go. this way is a little more difficult adn have more of a chance of breaking the window.
i did it #1 the first time but #2 should work but it will require more precise movements of the glass
Kyle
Old Dec 22, 2003 | 09:14 AM
ass15's Avatar
i got it done.............but thanks
Magius360
Mar 31, 2011 02:54 AM
Michael.Timz
Dec 8, 2007 05:37 PM
dark_controller
Feb 24, 2005 07:45 AM
yektik99
Jul 22, 2004 10:06 PM
MykeCo
May 19, 2004 08:02 PM
