in which i build a junkyard turbo kit....
Old Jan 16, 2003 | 02:50 PM
spitz7985's Avatar
looking to spend under $1 grand
looking for about 7psi and about 200 whp
junkyard turbo- dsm or 300zx possibly
manifold
downpipe
oil lines
coolant lines
flexible intake piping/apex cone filter
breather filter
junkyard intercooler
some sort of FMU- apex maybe(but their website says that you need an apex shop to install it), or possibly an AIC (http://www.rbracing-rsr.com/rsraic400.htm)
fuel pump
comments/opinions anyone? (especially on FMUs)
Old Jan 16, 2003 | 03:39 PM
rudeboy's Avatar
sounds good..i like the idea.
be sure to let us know what parts you use and all that. and take pics
Old Jan 16, 2003 | 03:41 PM
rudeboy's Avatar
and check your PM's
Old Jan 16, 2003 | 03:56 PM
Limited240sx's Avatar
Apex is ****, don't go with them. I've read numerous articles on their FMU's and many have disliked them.
Also, under a grand REALLY is pushin it. The reason is that the manifolds have to be made custom (which makes it difficult) along with the downpipe flanges. Be scepticle of the junkyard intercoolers. There's a reason they're in the junkyard, (if you know what Im saying haha) so a junkyard cooler might be dificult to get a hold of. Boost controller and BOV will also needed to be added to the list.
Also, how many miles do you have on you're engine? If its an high mileage engine you need new headgasket and piston rings. (so do a compression test as well). You can run it without these dont, but be careful.
New things to add to list:
clutch, exaust, ecu reprogram
Also, I thought you were looking into the kit from nsport.
But a junkyard turbo would def. be a good option to choose.
As for under $1000, i dont think it can be done effectively.
at least 1800 would be my guess. I say this because when you start researching for places to buy these products, that it's not as easy as it looks.
Dont go cheap on anything you do, beause it will end up costing you in the long run, as many ppl on this board will agree.
If I think of more I will notify you.
Old Jan 17, 2003 | 08:39 AM
spitz7985's Avatar
my dad is an EDM specialist (glorified machinist), so i can get parts fabricated for a good price (manifold and downpipe).
i did forget about the BOV, which will be recirculating
i am planning on welding in an exhaust dump before the cat, so with a pull of a cord, i will be dumping, but otherwise i'll run quietly on the stock exhaust
if i get an FMU, do i need an ecu reprogram?
my engine has 100,000 miles on it (middle aged for a nissan), but it passed its compression test with flying colors
as for the intercooler, i'll probly look for an eclipse side mount or maybe buy someone's sr20 stock IC
btw, thanks for your opinions. let me know if you think theres anything else i should know.
o and the nsport kit- $4 grand is a lot of money, i think i can do better for less
Old Jan 17, 2003 | 11:18 AM
Justin.b's Avatar
Mitsubishi Starion / Chrysler Conquest had a good sized front mount intercooler you may want to check out.
-Justin
Old Jan 21, 2003 | 08:26 PM
spitz7985's Avatar
any other recommendations on an FMU?
what do u guys think of this. kinda looks like a hackjob, but if it works, its good enough for me- http://www.rbracing-rsr.com/rsraic400.htm
clubredsilvia
Mar 26, 2007 06:34 PM
battosaii930
Mar 15, 2007 11:16 PM
EDog
Mar 31, 2006 08:21 PM
Zak
Aug 30, 2005 02:41 PM
irax
Dec 5, 2003 09:39 PM
