I need advice asap
Old Sep 14, 2004 | 10:21 PM
CaTcH_My_DRiFT's Avatar
I need advice asap
I have a 91 S13 Le .. it has 153K on the KA ... it burns oil but its weird , it only burns oil sometimes , like one day it will blow out white smoke kinda bad and the next day it wont smoke at all , But it smokes all the time when im idling for a while and hit the gas, any1 know what thats all about? i bought the car a month ago
And im planning on getting a swap .... but theres a big problem ... its an automatic , do u think its worth gettin it swapped to manual?
Thanks guys
Old Sep 14, 2004 | 11:43 PM
1) Could be the rings are giving out, compression checking your engine will give you a little more info on the problem.
2)Yes it...unless you like having a auto
Old Sep 15, 2004 | 12:40 AM
TheBull's Avatar
what kinda engine swap you gonna do?
Old Sep 16, 2004 | 09:22 PM
Im gettin the s14 sr20 swap .... i think im gonna get it done by heavy throttle cause ive heard good things about them and they are like 5 miles from my house .... they have done auto to manual swaps and i guess there customers are happy ... hopefully this goes well .. im kinda nervous about the auto to manual .. if any1 has had the auto to manual 5 speed tell me how everything went
thanks guys
Kyle
Old Sep 16, 2004 | 09:44 PM
Battle Pope's Avatar
Auto to Manual is cake as long as the pedals and hardline get set up correctly.
Old Sep 16, 2004 | 11:53 PM
Catch, no problems with the Auto to manual. It isn't really hard...just takes some time. You will be glad you did it
Old Sep 17, 2004 | 01:21 AM
GoGo240's Avatar
Catch, I highly recommend you get that auto to manual swap.
Like hyjynx said, its easy, but takes time.
I had mine done at Motorex, just remember to get a short throw shifter when you change transmission. It will help you in the future.
Putting that aside, why don't you go for the s13 sr20det blacktop?
Since the engine is almost dead, you should revive it with a sr.
I would do so if my car didn't have low mileage.
-Brian
Old Sep 17, 2004 | 09:37 AM
The Short shifter is a great idea
Old Sep 17, 2004 | 10:06 AM
iNi_REALized's Avatar
White smoke usually indicates a blown head gasket.. while heavy black smoke usually indicates worn piston rings.
Old Sep 17, 2004 | 11:33 AM
I guess my headgasket is done for .. but its all gravy
I want the s14 blacktop sr20 because its got variable valve timing and a larger turbo ... and at heavy throttle the s14 is onnly 200 more dollars , but im not sure
Well u guys are a good help
thanks
90two4tsx
Oct 20, 2003 01:16 PM
esanmiguel
May 21, 2003 09:19 PM
anarchyfox
Apr 28, 2003 02:46 PM
TNTBOO
Mar 20, 2003 07:30 PM
ZKrazy
Feb 10, 2002 06:26 PM
