Idel fluctuating after engine is warmed. what happened?
well my engine runs fine when it started but the problem occure after the engine is warmed sometimes then engine even stall. there is no engine code and the engine check light is not on....... I have new plugs and new wire...... where else should I check?
I have the same problem. I don't know if I fixed it yet or not.
Are you running rich?
What kind of gas are you running?
If you can rev past 2500 it's not the MAF.
It's possible that the spark isn't powerful enough because of an old distributor cap and rotor.
j00ni3
Sep 18, 2005 09:47 PM
jackyliem
Jun 12, 2005 10:03 PM
SilviaJai
Sep 23, 2003 07:36 AM
