Ignition 12volt
Old Aug 18, 2005 | 03:59 PM
djradam's Avatar
Ignition 12volt
Hello,
Some dumbasses who owned the car before me did a crappy job on the radio. anyway, i can directly wire the radio for power and ground, but i'd like the use the ignition 12volt (i COULD directly wire it, but don't want to forget to turn off the radio). i think a ton of applications tap into this ignition 12volt. anyone know a good spot? i tested the radio harness and i get nothing out of it and i checked all the fuses.
thanks!
Old Aug 25, 2005 | 09:21 AM
ignition wire is somewhere near the steering column, so look there. true - a ton of stuff taps into the ignition circuit, but they all use small wires and might not be able to support running a head unit off of.
cavell
Jul 7, 2003 10:41 AM
ZeR0
May 13, 2003 09:31 PM
wushu4u
May 1, 2003 12:08 PM
nismo24t
Dec 5, 2002 05:34 PM
Jonas
Oct 22, 2002 05:22 PM
