installing atima fans for dummies please help
I need a write up for installing altima fans on my s14. I have seen the one on n i co club and I am like huh????. Does any body know a writeup or can do a write up on how to install altima fans for dummies???? w/pics please.
i don't remember what the wiring is like on those fans so i'm not sure if this will do you any good or not.
http://www.club240.com/forums/showthread.php?t=41909
i see so you want to control when they are on and off. in that case no just find the +12v switched for the ac relay and plug the + wires in there. that was originally what i did but i thought it best to let the thermostat switch turn the fans on and off.
Besides you use battery power in some cases when the fan isn't needed at all such as wehn you are on the freeway.
Okay, I was looking at my fuse box and noticed I have 2 relays one says rad fan low and the other says rad fan high?? also I have a 30 amp fuse that says rad fan. I was wondering if these are for hooking up the dual electric fans??
as long as you don't draw more current than the fuse is rated for there isn't a difference. the problem comes when you use a higher rated fuse than the wires can handle. then rather than the fuse blowing your wires catch on fire. i assume you are using relays or a relay for the thermo switch.
if so the relays i've seen for the switches tend to be rated at 30amps. i believe the thermo switch is 25amps. so just use any thing that has the same rating as the lowest rated device, in this case the therm switch. i play it safe when it comes to wiring and go with the lowest possible fuse that will supply a sufficient amount of amps but will blow before causing any damage.
raccoon601
Oct 25, 2005 07:08 PM
