intake?
Old Jul 24, 2005 | 03:44 PM
BigVinnie's Avatar
Originally posted by steve 14
short intake has pick up from 3000 to 8000 rpm
That is clean man, I give you props.
Personally I want to make mine super short eventually, just have maf to the tb, and just a filter, no tubing.
WHAT the HELL, is that a red bull can where the cruise control should be???????
Old Jul 24, 2005 | 03:49 PM
shotty53's Avatar
i need my battery.. i have a 1200 watt amp running 2 speakers.. but i am interested in the u pipe... know where i could possibly relocaate my battery at ease other than the trunk
Old Jul 24, 2005 | 03:51 PM
BigVinnie's Avatar
Actually the battery is best in the trunk from the back and dead center, gets those donuts swingin'.
Old Jul 24, 2005 | 04:03 PM
steve 14's Avatar
thanks
the can is for crank case blow by
insted of having all that nasty **** going back into the manifold
Old Jul 24, 2005 | 04:05 PM
steve 14's Avatar
trunk or behind the passager seat
just mack sure you get a sealed box if you don't have a dry cell battrey
Old Jul 24, 2005 | 05:41 PM
down_shift's Avatar
Or get a smaller battery, like a bike, lawnmower, aftermarket race one. I think you could use a cap for the sound system without issue.
Old Jul 24, 2005 | 05:46 PM
steve 14's Avatar
Originally posted by down_shift
, lawnmower,
thats what i'm using $20 wallmart
Old Jul 24, 2005 | 08:07 PM
shotty53's Avatar
so if i do replace my bettery... any1 got a tutorial on how i would move my wires from the hood to the trunk..
srry... im really new to car modding..
Old Jul 24, 2005 | 08:22 PM
BigVinnie's Avatar
Lightning caps are a defenite plus. When it comes to batteries that are smaller than normal it would probably be an optima battery.
Old Jul 25, 2005 | 05:25 AM
shotty53's Avatar
i figured out how to relocate the battery.. only 1 last question i hope.. how big does the "u" pipe need to be? like 8" and bent at 30 degrees?
and steve 14.. i remove all the stuff on the right side, or is that optional stuff that you removed along with the stock filter stuff?
Old Jul 25, 2005 | 10:42 AM
  #26
shotty53's Avatar
ok... i need to keep this part and reconnect everyting to it correct...
and can i use the pre existing tubing (green) and attach a 3" pipe to it, or no?
Also (in red) these 2 tubes get plugged.. correct
Old Jul 26, 2005 | 12:30 PM
  #27
shotty53's Avatar
any one know please.. i have thursday and was was looking into doing it then
Old Jul 26, 2005 | 12:55 PM
  #28
down_shift's Avatar
Yes the first pic is correct for your maf. I am sure you can reuse the rubber circled in green but a silicon coupling would be better. I am sorry I don't know about those two hoses. Good luck with the project.
Old Jul 26, 2005 | 04:06 PM
  #29
steve 14's Avatar
go to pepboys or discount auto
buy a civic intake $30
get a hack saw and cut it
take all athe stock parts off
your going to need to get a adapter for the cone filtter that will bolt on to the maf where the stock air box bolts on
Old Jul 27, 2005 | 08:43 AM
  #30
Tanshin's Avatar
heres mine
I did the same thing, kind of, but the space is tight and the hose for the rad sits too close to the intake pipe. Gets the pipe real hot which makes the air real hot.
Now, I don't know if this will equal out when my header is on. It might. That was my reasoning in the first place. The header is going to make the drivers side bay hot as hell on the s14.... is that where I want my intake air coming from?
Also, I hear you get better throttle response from the shorter intake. It felt real nice to me when I had it on but I had no money for a dyno so who knows.
Until then, I put my AEM back on and I'm real happy with it and the sound is nice too.
