Its been a long time....headlight question?
Old Mar 12, 2007 | 09:44 PM
bucket240's Avatar
Whats going on guys? Sorry I have not been visiting the forums like I am sappose to! I have been hella busy moving to a new spot that has a garage so I can do my swap and yes that was the main reason for moving. Anyways how have everybody been? There is so many post that I have to catch up on. Okay now to my question.... My headlights are all f'ed up. One is brighter than the other and some of it doesnt work. I mixed them up and I took the brighter bulb off and put it on the dimmer side and soso... the dimmer side made the brighter bulb dimmer?!? and the brighter side made the dimmer bulb brighter??? I am so confused
Old Mar 12, 2007 | 10:44 PM
check grounds relays and fuses. chances are that the reflective surface on headlamp bowl is just worn or hazed over. the only option you would have in that case would be to replace the whole assembly.
Old Mar 12, 2007 | 10:54 PM
re037's Avatar
its not the bulb. check the wiring. and welcome back =)
Old Mar 13, 2007 | 06:13 PM
LA_phantom_240's Avatar
Wiring. Upgrade. Now.
Relays and bigger wiring really do wonders.
Old Mar 13, 2007 | 06:54 PM
bucket240's Avatar
Its not the bulbs because I just bought new ones and they did the same thing, so I returned them. My fuses are fine, where are my relays?? Another thing... My left inner head light is not getting any power on regular on but when I turn on the high beams it gets power...
Old Mar 13, 2007 | 08:45 PM
bucket240's Avatar
Okay nevermind I figured it out! I grabbed a beer and a small chair and sat in front of my car thinking real hard, I noticed the passenger side harnes had a new plug so I followed the wire up the the harness and who ever installed the plug got the wires all fiicked up. So I rewired it and it worked, thanx anyways guys.
Old Mar 14, 2007 | 11:36 PM
cronux's Avatar
so beer does make you smarter!
silviasichigo
Dec 7, 2010 07:25 AM
slimbung
May 2, 2007 07:22 PM
Silviaspeed
Dec 25, 2003 12:49 PM
rameek
Oct 14, 2003 07:36 AM
