KA24DE vs Ka24E
Old Dec 7, 2005 | 05:48 AM
flipsideS13's Avatar
Question KA24DE vs Ka24E
hi all, im new to this forum and i finally got my 240sx. my 240sx has the KA24E motor. i reviewed this link http://www.socal**********/faq/1990.html to get the specs of my car and compared it with this link http://www.socal**********/faq/1991.html. comparing the 2, between the KA24DE and the KA24E, the extra cam only makes 5 HP o_O. reason why im posting this is because before i even had the car i was planning to swap in the KA24DE. considering all this, is it even worth getting the swap? i used to be into hondas, between D16 and the B16 the HP difference is alot, i know B16 has more compression and all, but still.....
thanks.
Old Dec 7, 2005 | 06:20 AM
BigVinnie's Avatar
The extra cam doesn't make 5 HP. The larger cam duration specs, ecu tune, and much larger porting of the DE head make it a much better engine over the E.
Way more tunable features using the DE.
SOHC is great as a torque monster, but with solid lifter assembly don't expect any superior reving over the DE.
Old Dec 7, 2005 | 06:39 AM
i see, thanks for the info. btw, u know a good trusted site that sells reasonably priced KA24DE engines? actually F it ill search the forum, thanks.
Old Dec 7, 2005 | 09:20 AM
PNG's Avatar
PNG
I'll take the SOHC off your hands once you don't need it any more...
Old Dec 7, 2005 | 01:40 PM
cool if you came from honda, get use to less wiring for low end swaps. remeber for example if u ever swaped a b18a1 ( or any MPFI motor) into a older DX ef u have to do DPFI to MPFI and add the extra wires for the dizzy etc which is easy, which i have done or just do a full Si body wiring which i have done also lol. My DOHC KA swap was seriously a 3 hour job with all the parts and tools both times ( Yea Both). and car lift would help. I have always owned nissan but i know alot about honda too.
all u need to do the swap
welcome
http://www.zilvia.net/faqs/archive/SOHCtoDOHC.asp
Old Dec 7, 2005 | 06:05 PM
PNG
i just noticed that your running a KA24E with 60 shot
how is that working out? beefed up internals? bigger injectors? better fuel pump? tuned ECU? etc....
Old Dec 7, 2005 | 10:48 PM
PNG's Avatar
PNG
It's working out great. 20+ passes at the track, and maybe 15 dyno pulls, and I drive the car 150 miles a day to and from work. It's a wet kit, so the injectors and ECU are still stock. I put in a new Walbro 255 lph fuel pump for safety's sake, but it ran fine on the bottle without it. The motor is bone-stock internally. I went a step colder on the plugs, both because of the spray and because of all the freeway driving I do. Right now the timing's stock, but judging by where the 'blue line' is on the plugs' ground straps, I'm going to start taking out a couple of degrees when I run it hard at the strip.
If I had a spare motor handy, I'd be putting the "75 shot" jetting in... :-P
S13freak
Jun 21, 2004 10:27 AM
Tempest
Feb 12, 2004 10:31 AM
spliffstar
May 9, 2003 07:42 PM
xriz
Nov 22, 2002 02:42 AM
spliffstar
Oct 7, 2002 06:23 PM
