my 1995 a OBDI or OBDII
Old Feb 13, 2006 | 08:21 PM
BigVinnie's Avatar
HAHA like yeah BEVIS, you said HOLE
Old Feb 13, 2006 | 08:43 PM
dued's Avatar
Thumbs up
Oh gosh this stuff is getting crazy.
Old Feb 14, 2006 | 02:41 PM
barcode's Avatar
ohh haha, I finnaly found out it is an OBD II one by the way. just figured I would point it out, another 95 OBDII
Old Feb 16, 2006 | 09:58 AM
soreballz's Avatar
Is there any way you can tell if its ODBI or II while the engine is out of the car? The parts car I bought (89 hatch) had a twin cam from a 95 swapped into it, and the car it came out of is long gone, so checking VINs, second o2 sensors and butted cats doesn't do me much good.
Anyone have any ideas?
Old Feb 16, 2006 | 01:00 PM
If it was swapped into the other car, and ran correctly it shouldn't really matter because if it was OBDII they would of had to made it work like an OBDI
Old Feb 18, 2006 | 04:56 AM
KeN VeRsUs RyU's Avatar
from my research.. the easiest way to decipher the obd saga is to look at how many wires are on your existing oxygen sensor and harness. If its 1.. its obd1.. if its 3.. obd2
if the engine is out of the car.. look for the oxygen sensor harness.
Old Feb 21, 2006 | 02:45 AM
joh's Avatar
joh
The vin will tell if it is an obd1 or 2 right?
Old Feb 21, 2006 | 03:06 PM
Joel SX's Avatar
OBD2 o2 sensors also have many cables on them, while the obd1 has only one. OBD2 engines have more bolts on the valve cover than the OBD1. OBD2 are better, obd1 are easier. OBD1 rocks, obd2 sucks...... b/c I have obd1 and I say so.
Old Feb 23, 2006 | 03:54 PM
Joel SX's Avatar
I've found a big diference in the two engines!!!!!!!
If you go to my profile and read my other post, you'll se that recently, I blew my engine. as a result I bought a 95 engine. thsi one after opening it, I saw that it was also shot. So the guy took it back and gave me another engine from a 95. now this one as I saw it compared to the other 95, I imidietly knew it was a OBD2
So the universal answer has been discovered: how to know if your engine is OBD2 or 1?????? Look at the distributor, if it has 4 spark plug camles comign out its obd2 since the coil is INSIDE the distributor. If it has 4 cables and 1 in the midle going to a Coil outside then its OBD1!!!!!
Yay all migthy joel of knowlege!!!!!
Now my car is OBD1, so my next post will be this sticky:
"How to install a OBD2 engine into a OBD1 harness!"
Old Feb 25, 2006 | 07:29 AM
barcode's Avatar
ummm.....so its OBDII either way lol, i think you need to fix that.
Old Feb 25, 2006 | 08:07 AM
  #26
I thought it was s13's that had the external ignition coil while all s14's had the ignition coil in the distributor
Old Feb 28, 2006 | 02:20 PM
  #27
Joel SX's Avatar
Well the first one he gavem e was out of a 95 and it had the Coil outside. and then he pulled another 95 and it had it inside
Old Mar 3, 2006 | 10:38 PM
  #28
ConceptS14's Avatar
sorry to burst your bubble, but i have a OBDI (manufactured 9/94)and have an internal coil.
i believe that's a S13/S14 difference.
as someone else pointed out above, the difference is in the number of wires on the O2sensor.
Old Mar 4, 2006 | 07:25 AM
  #29
barcode's Avatar
Well, the front O2 on my car has one green one. But then I got the rear O2 Sensor and it has 3 wires on it. So....
Old Mar 15, 2006 | 10:58 AM
  #30
barcode's Avatar
any body have any ideas about what i said, i still need to know this stuff,
