NA rwd sr20de
Old Sep 12, 2003 | 10:00 PM
paNX2K&SE-R's Avatar
NA rwd sr20de
Anyone know of any sources for an na rwd sr20de and maybe approximate prices? Thanks
Old Sep 12, 2003 | 10:35 PM
I'm with Stupid's Avatar
I've never seen them anywhere other than eBay, because IMO and I'm sure many other people agree they're a complete waste of of money. Importers don't bother, so you'll have to "special order" one.
Old Sep 12, 2003 | 10:49 PM
I can understand how someone thats not from an SR20 background would think that. I had a det swap in my 91 SE-R which is for all intents and purposes the same as a redtop rwd det motor and it was great. However, if the stock engine wasn't beyond repair I could have used a bolt on kit and made more power. The na sr20 is just as good as the factory det. The oil squiters don't make that much of a difference. You can safely run a t28 at 14-16 psi on a 9.5:1 compression engine and make more power then a 8.5:1 det. It just happens that the current mindset of the 240 crowd is that you *have* to have the factory det motor for a good turbo setup. This was the same mindset the fwd sr20 crowd had 4 years ago before it became common knowledge that a bolt on de setup was just as good. The whole rwd sr20 movement is still in its infancy and there is still a lot left to learn for most of the 240 crowd.
Old Sep 12, 2003 | 11:03 PM
TruDirtyPlaya's Avatar
Umm.. Lol, just thought it would be cheaper to just turbo a sr20de than just buying a det...
personally I'm trying to figure out how to put in a rb26, thought about a custom turbo manifold shifting the turbos foward more...
looks like I'm going rb25 though... easier/cheaper install
Old Sep 13, 2003 | 05:18 PM
The SR20DE also has a smaller oil pump, and does not have a coil on plug ignition. Even if for the sake of discussion they were exactly the same in all ways with the exception of a turbo, the money you'd waste on importing a SR20DE (which will be slower than the KA) and then bolting on a turbo would be ridiculous.
Old Sep 13, 2003 | 06:06 PM
Sorry that is not true. Only the GTiR has a bigger pump.
That makes no difference unless you are making over 400 whp.
If you could get one for $600 then you would be way ahead of the people that pay $2000 for a det...
Again, I have no ill will towards the people in the 240 crowd that are new to the SR20 engine. The learning process doesn't happen overnight...
Old Sep 13, 2003 | 07:16 PM
Rittmeister's Avatar
This is really interesting. If you find out where to get an NA RWD SR, let us know.
I wonder how hard it is to source the OEM turbo stuff for a RWD engine...
Old Sep 15, 2003 | 06:47 AM
NightXCZ77's Avatar
I believe I have a few available if you are interested....please pm me for details.
prospec240
Sep 18, 2005 11:34 AM
GDubInVegas
Oct 4, 2004 02:08 PM
irax
Dec 9, 2003 09:40 PM
positron
Oct 13, 2003 03:28 PM
GRTseR
May 12, 2003 11:33 PM
