need Help with planning
ok im planning on getting a base model s13 fastback
what should i do with 200$???
besides buy an intake* how many things could i buy for 200$ that would benefit the performance of a KA fastback?
* I just wanna see how minds work in this forum =0)
Originally posted by thelinja
How about you take the $200 and make sure everything on the car works right.
hmm..you tell us
Preventive maintence buddy! Get a new battery, get new sparkplugs and sparkplug wires, get new serpentine belts if needed, flush out your radiator, drain and replace transmission fluid, oil change ( get MOA if you got oil gunk build up ), fuel filter replace, get new..hmm...cant really do much with 200.
And this is with installing and doing on your own, if you get a shop to do it..it will be a lil more than just 200
If you suspect carbon build up on valves and whatnot, there is services at Goodyear that can clean that for like...59.95 (used to work at goodyear )
hahaha thanks!!! i think im going to start with buying new spark plugs, getting a fuel filter, oil filter, custom CAI, nismo thermostat, new o2 sensor, gonna try to rid of the carbon build up with RESTORE, change tranny fluid, oil etc, and flush out my radiator. Then gut everything out to the 30 pound sound deading black $hit... =0)
just need a few suggestions on:
What spark plugs should i get? I was thinking about bosch
And i read some where that a 300zx fuel filter is best
Getting a mag II power enterprise oil filter
Bosch o2 sensor
AND WHAT IS FLUSHING OUT UR RADIATOR? (sorry im still a newb >.<)
Bosch o2 sensor
flushing as in ..drain it as much as you can , then pouring water into it till it is clear of all trace of old coolant..then putting in brand new fresh, like it came out the factory.
i'd suggest getting some MOA from goodyear if you want your oil routes bling bling and virtually black oil trace free. Just add it in with your next oil change and watch the magic happen on you oil dipstick. ( i stole some from my work and it works very well indeed )
Get NGK sparkplugs if you can.
S13freak
03-11-2004 12:12 PM
