noob tech question
Old Jun 14, 2006 | 11:00 AM
ka-tfresh's Avatar
noob tech question
Ok guys, what exactly happens when you "throw a rod"...I've seen the aftermath, but what goes on inside your engine to throw a rod???
Old Jun 14, 2006 | 11:52 AM
PNG's Avatar
PNG
Well, ether the rod breaks, the wrist pin breaks, or the rod cap or cap bolts break. It can happen in compression (although usually the rod just bends in that failure mode) or tension, which in my experience is more common.
Old Jun 14, 2006 | 02:18 PM
ka-tfresh's Avatar
cool...thanks, yea, you see the oddly bent rods and big holes in the block and you go ...how the hell did that happen???
Old Jun 14, 2006 | 02:21 PM
barcode's Avatar
yea, i saw the after math of one breaking and i kinda figurd it out from that, when i saw the rod sticking out of the oil pan. too bad there were no big holes lol.
Old Jun 14, 2006 | 04:24 PM
PNG's Avatar
PNG
Interestingly enough, most of the time that a rod breaks it's in tension on the intake stroke, not compression. If you think about it, 3/4 of the time the rod doesn't even need a cap on the big end because there's always pressure on it. But once the exhaust stroke ends and the crank has to drag the piston back down the bore, there's more force than you'd think. Spin an engine too fast and get the piston speed up high enough, and the inertial load can pull the cap right off.
Old Jun 15, 2006 | 07:24 PM
ka-tfresh's Avatar
^^^thanks, i got a much better sense of the situation now
haha...light bulb
nuS13
Feb 10, 2011 08:31 AM
BboyJon
Jan 23, 2006 10:07 PM
240sxFan
Sep 22, 2004 12:50 AM
Zdrifter
Feb 27, 2004 06:59 PM
Bing
Aug 16, 2003 06:39 AM
