OIL grade
Old Mar 11, 2004 | 03:52 PM
GUNLINE's Avatar
Talking OIL grade
I wanna do a oil change just wondering what grade of oil i should use? like 5w 30 or something i have no idea what the hell that means. my engine is at 100 000 right now and occasionally i drive it really hard. I hear royal purple and mobil 1 is good just wondering what grade of oil is best?
thanks
Old Mar 11, 2004 | 05:28 PM
It says 5w30 in the manual i believe
Old Mar 11, 2004 | 09:06 PM
jackyliem's Avatar
I saw a chart in the chilton manual and they said it's either 10w-30 or 10w-40. people also said the closer the two number are the less composite it's gonna produce so I guess 10w- 30 would be the best choice. other than that can 240sx use synthetic? cuz my friend has a RX7 and the manual said it can't use synthetic on it.
Old Mar 11, 2004 | 10:12 PM
sr20det power's Avatar
thats weird synthetic is better than other not fully synthetic oils, n maybe it says that for the RX7 cuz its a rotory engine?
Old Mar 11, 2004 | 10:27 PM
You should be able to use synthetic, no prob
I suggest 10w-30, or 5w-30
Old Mar 12, 2004 | 07:02 PM
hitokiri_808's Avatar
10w-30 is what i use.
synthetic oil doesn't burn the same as dino oil, and since rotary engines burn oil by design you would have a problem using synthetic.
Old Mar 12, 2004 | 08:38 PM
nis-s13's Avatar
i'm also confused on what type of oil to run. in my ka24de i was running 10w-30 synthetic... should i run it in my sr also?
Old Mar 13, 2004 | 12:19 PM
devnull's Avatar
10w-30 means it will flow like 10 weight oil, but lubricate like 30 weight oil. The 'w' means that it has passed SAE viscosity versus temperature tests.
Old Mar 14, 2004 | 10:59 AM
thelinja's Avatar
No, the first number indicates that the oil's viscosity when it's cold, and the second number idicates the viscosity at operating temperature.
As far as my opinions on suggested oil weights go, I use 10w-30 in the winter ( but use 5w-30 if it gets really cold where you live) and then I use 20w-50 in the summer.
Old Mar 14, 2004 | 12:29 PM
devnull's Avatar
You're right...what the heck was I thinking?
This one's for you...
Old Mar 14, 2004 | 02:31 PM
thelinja's Avatar
It's all good.
If you guys want to learn more about oil go to www.howstuffworks.com and search for "oil weight"
boosteddet
Jun 12, 2008 05:42 PM
CowboyTurbo
Jul 2, 2005 07:29 AM
cticknor666
Oct 22, 2004 03:24 AM
james_s14
Oct 10, 2004 08:42 AM
