Oil Leak on ka
Old Sep 10, 2009 | 06:42 PM
peng's Avatar
Oil Leak on ka
So i was at My Girls house.. pulled into the shed and then backed out and found a moderate size oil puddle on the floor. This is just after i thought i heard a slight knock in the engine.... checked the oile and it didnt even hit the bottom of the dipstick... where could be the culprit, im hoping that it is like the ring on the oil filter that blew out cause that is easy. the engine has 270 thousand on it..... then my nexy question is if it is bad do i set the car and wait till i can get a engine swap in it thought about a ca18t or a ka24det. i am great with a wrench but if it means that i have to do a rear seal i might as well just rebuild and turbo the ka... does any one know of a good kit to rebuild the ka and make it turbo ready?
thanx Ty
Old Sep 10, 2009 | 07:11 PM
Lord Umoja's Avatar
Dunno about your oil leak but if you wanna go KA-T I have a good list of internals. I have a built KA sittng in my shop, just wish I had the cash for put the turbo on. Parents hit hard times so I put my car fund to supporting myself so that I'm not a drain on them.
Old Sep 10, 2009 | 07:33 PM
Nickmerrone's Avatar
go to ka-t.org. theres a link on there for a full rebuild kit for 1200. many options.
Old Sep 10, 2009 | 07:35 PM
Lord Umoja's Avatar
My internals ran me just over 800 I think... The AMS kit is overpriced.
Old Sep 11, 2009 | 07:01 AM
peng's Avatar
well im interseted in going to a ka-t. theres a junk yard around here that has a ka single cam i think is has alot less miles than mine does i though about using that block the 5 speed behind it my de head and going from there could you send me you build list i cant find any sites other than ams that has ka stuff,
Old Sep 11, 2009 | 12:46 PM
240smoke's Avatar
check to see if you have a hole in the side of your block lol
Old Sep 11, 2009 | 03:16 PM
based on the description, a hole in the block sounds possible. or the knocking could be the result of no oil being circulated. with all those miles, oil leaks are fairly common around the main seals, oil pan, valve cover, timing chain cover, and just about any other place where oil flows. your engine is tired and want's to go home.
Old Sep 11, 2009 | 03:58 PM
Cr8zyDrifter's Avatar
My Engine is tired too. Leaks a bunch of oil and now powersteering fluid. so no more power steering. Oh and now the radio doesnt work, and the AC/heat controls are messed up so i can only turn on fan, on either cool or hot. nothing else no feet warmth in the winter no defroster. It is the essence of the S13. and I still love it. lol still runs strong though. hahaha
Old Sep 12, 2009 | 11:42 AM
Lord Umoja's Avatar
The Internals I'm running are as follows (Off the top of my head)
Arias 8.8:1 Pistons (Bough from Arias, call them and work a deal)
Eagle ESP H-Beam Rods (Bought From Arias)
Cometic Head Gasket (Bought from Arias...Same deal at the others)
Clevite Bearings (Not sure where I bought them...Believe AMS)
ARP Head and Main Studs (Bought from AMS)
Gaskets, and timing equipment bought from Advance Auto Parts
Whole setup cost me in the range of 800-1000
slidewithpride
Aug 12, 2011 09:51 AM
Roscutoo
Feb 2, 2005 11:16 PM
240kid
Jun 30, 2004 11:14 PM
sr20fan
Sep 24, 2003 07:05 AM
rudeboy
Sep 28, 2002 07:56 AM
